Robert
Solutions to the network connection problem of smart TV and box:
First, you need to know what's wrong with smart TVs or boxes. Here's a quick analysis of different situations:
1. Computers have Internet access, but TV boxes don't
This problem is usually caused by the inability of the TV and box to obtain IP. The most effective and simple way is to restart the router and preferentially connect to the TV or box.
2. The router is working, but not connected to the Internet:
If the WIFI signal cannot be found, confirm whether it exceeds the coverage range of the WIFI signal. If it is close to the router and other devices can be found, but the box cannot be found, it may be that the WIFI module is faulty and needs to be repaired. Or use network cables to connect to the Internet.
3. Connected to the wireless network, but unable to access or loading
In this case, or has been stuck in the loading page, can not normally open the program, similar problems are likely to be related to the network speed, you can download the Dangbei Assistant, use the network speed measurement function. If the network speed is slow, there may be a problem with the DNS Settings or the DNS server has been hijacked.
