Sony Echo Wall HT-RT5 review: not a cost-effective choice
Bread Pitt
Sony Echo Wall HT-RT5's software settings are in place, basically fool operation, the remote control can be done in steps. If the repeater is not activated, the TV can be remotely controlled by raising the hand, and there is no need to install it.
Sony HT-RT5 user review
However, this Sony Echo Wall HT-RT5 sound is disappointing. The Bluetooth link from Sony Echo Wall HT-RT5 to mobile phone plays Lossless Sound Quality, the surround sound is not obvious in distance of 3.5 meters, the middle field is obviously disconnected, and there is empty space. The two surround speakers of Sony Echo Wall HT-RT5 do not work well and are not transparent. Through HDMI (ARC), the serious loss of sound in HT-RT5 is that the set-top box, TV, and speakers must be turned to two-thirds of the volume to have an effect. Following the data audio cable can solve this problem. Unfortunately, it is not equipped, so you have to buy it yourself.
Sony Echo Wall HT-RT5 user review
Sony HT-RT5 ​
It may be effective to cook Sony Echo Wall HT-RT5 for a while, but the power of the two surround speakers is too small, which is very tasteless. It is better to buy Sony HT NT5, with add two more powerful speakers, the effect is much better than this. It works well with Sony TV. Besides Sony Echo Wall HT-RT5, Sony still has its own advantages.
