Unboxing Experience
- 1.1.1 Tecaki Mini Projector:
- 1.1.2 ear&ear HY300 PRO Projector:
- 1.1.3 ENUOSUMA Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 Tecaki Mini Projector:
- 1.3.2 ear&ear HY300 PRO Projector:
- 1.3.3 ENUOSUMA Mini Projector:
- 1.4 Features
1.5
- 1.5.1 Tecaki Mini Projector:
- 1.5.2 ear&ear HY300 PRO Projector:
- 1.5.3 ENUOSUMA Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
| Parameter | Tecaki Mini Projector | ear&ear HY300 PRO Projector | ENUOSUMA Mini Projector |
Picture | |||
Reference Price | $49.99 | $59.99 | $59.99 |
Recommended Uses | Indoor/Outdoor | Education, Home Cinema, Gaming, Business | Education, Indoor/Outdoor, Home Cinema, Gaming, Business |
Built-In Media | User Manual, Warranty Card, Remote, HDMI Cable, Cleaning Kit | User Manual, Power Cord, Remote | Projector, Power Cord, infrared remote |
Highlight | Resolution: 1080P HD Bluetooth Version: 5.2 Compatibility: iOS, Android, Bluetooth-enabled devices Projection Angle: 180° rotatable Keystone Correction: Advanced auto-keystone Zoom Function: Adjustable from 75% to 100% Design: Mini, portable, lightweight | Smart Projector Operating System: Android TV 13.0 App Ecosystem: Access to mainstream streaming services, over 500,000 movies and TV shows GPU: Mali-G31 Connectivity: WiFi 6 Projection Angle: 180° rotational Use Cases: Home theater, education, video conferencing Keystone Correction: Auto with manual focus adjustment Sound System: 360-degree surround sound Video Resolution: Supports 1080P/4K Brightness: 200 ANSI lumens Contrast Ratio: 1500:1 Noise Level: Below 25 dB Ports: HDMI, USB, audio Bluetooth: 5.0 Network Compatibility: 2.4G and 5G networks | Smart Projector with Android TV 11 Apps Available: Over 4000, including Netflix, Prime Video, YouTube Movie Library: Over 500,000 movies and TV shows Resolution: Native 1080P, 4K support Brightness: 200 ANSI lumens Contrast Ratio: 1500:1 Connectivity: WiFi 6, Bluetooth 5.2, compatible with 2.4G and 5G networks Projection Size: 35-130 inches Noise Level: Below 25dB Ports: HDMI, USB, audio Features: 180° rotating projection, automatic keystone correction, manual focus adjustment, 360° sound Use Cases: Home theater, entertainment, education, video conferences, online teaching |
Unboxing Experience
The Tecaki Mini Projector has a compact design, approximately the size of a 2-liter soda bottle, which makes it relatively portable and convenient for indoor use. While it may not be the smallest projector on the market, its lightweight nature is an advantage for casual users. However, I would note that the lack of a carrying case is a minor oversight, as it would help in keeping the projector and accessories organized. The remote control, which is included, does require batteries that are not provided, so keep that in mind if you're planning to use it right out of the box.ear&ear HY300 PRO Projector:
The Mini Projector HY300 PRO Portable Projector strikes me as a well-designed and compact unit. Its sleek, modern aesthetics give it a stylish look that fits into any environment, be it a home theater or outdoor setup. Its lightweight nature makes it easily portable, allowing me to carry it effortlessly in a bag for various occasions, whether it be movie nights at home or camping trips.ENUOSUMA Mini Projector:
The mini projector boasts a sleek and compact design that is both stylish and portable. Its 180-degree rotatable feature adds to its versatility, allowing for flexible positioning in various settings, whether for home entertainment or presentations. The lightweight build makes it easy to carry around, which is a definite plus for those who enjoy movie nights or gaming sessions in different locations.Display
Screen Size | 30 Inches - 200 Inches | 35 Inches - 130 Inches | 35 Inches - 1.3E+2 Inches |
Throw Distance | 3.2 - 16.4 | 35 - 130 | 1.2 Meters - 4 Meters |
Contrast Ratio | 10000:1 | 1500:1 | 1500:1 Pixels Per Inch |
Maximum Resolution | 1920x1080 Pixels | 4096 x 2160 | 1280 x 720 Pixels |
Native Resolution | 1920 x 1080 | 1280 x 720 | 1024 x 720 |
Brightness | - | 200 Lumen | 160 lumen |
Display Type | LED | LED | LED |
Viewing Experience
The viewing experience is quite enjoyable, particularly when the lights are dimmed. Colors appear vibrant and true to the source material, which enhanced our nightly routine of watching shows. However, I did notice some pixelation at the edges of the image when projected at larger sizes, specifically beyond 60 inches. The projection quality is adequate for a budget device, though it is best used in darker rooms to avoid washed-out images, particularly during the day. Overall, I was pleased with the performance for casual viewing, but I wouldn’t recommend it for serious movie nights in bright environments.ear&ear HY300 PRO Projector:
The viewing experience with the HY300 PRO has been nothing short of impressive. The projector supports 4K and 1080P resolutions, delivering sharp, vibrant visuals that remain clear even in moderately lit rooms. Whether I'm watching movies, gaming, or presenting, the image quality consistently meets my expectations. The projector performs exceptionally well on larger screens up to 130 inches, making it versatile for various settings. However, I've found that for the best picture quality, using it in darker environments yields superior results.ENUOSUMA Mini Projector:
The image quality of the projector truly impressed me, with sharp and vibrant visuals that support both 4K and 1080P resolutions. The brightness, rated at 200 ANSI lumens, is adequate for viewing in dimly lit rooms, and I was particularly pleased with the clarity and detail during movie nights. However, while the built-in speaker is decent for casual use, I highly recommend connecting external speakers for an enhanced audio experience.Features
Other Features | Short Throw | Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player | Built-In Apps and Android 11, 5G WIFI + 2.4G WiFi, Support 4K 1080P, Auto Keystone Correction, Built-In Media Player |
Video Encoding | AVC | AVC | - |
Lamp Wattage | - | - | 6E+1 Watts |
LightSource Life | - | - | 50000 Hours |
Controller Type | - | Remote Control | Button Control |
Control Method | - | Remote | App, Remote |
Connectivity Technology | USB, HDMI | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | Bluetooth, Wi-Fi, USB, Ethernet, HDMI |
Compatible Devices | Laptop, Gaming Console, Tablet, Smartphone, Speaker | Laptop, Tablet, Smartphone, Speaker | Laptop, Gaming Console, Television, Tablet, Smartphone |
Wattage | 45 watts | - | - |
Mount Type | Tabletop Mount | Tabletop Mount | Tabletop Mount |
L x W x H | 7.28"L x 5.2"W x 4.72"H | - | - |
Setting up the Tecaki Mini Projector was a straightforward process, especially when connecting it to my laptop via HDMI; it truly is a plug-and-play experience. I managed to mount it on my headboard using a small shelf and clips, which worked effectively within my limited bedroom space. Although I haven’t explored all the connection options yet, the HDMI setup was seamless and quick. The projector also features a manual focus and keystone correction, which made it easy to achieve a sharp image even at different projection angles.ear&ear HY300 PRO Projector:
Setting up the HY300 PRO was a breeze, and I was pleasantly surprised by how intuitive the controls are. The projector features an Android 13 operating system that includes a range of pre-installed streaming apps, eliminating the need for additional devices. The 180° rotatable design and auto keystone correction make positioning easy, ensuring that I can project images perfectly aligned on any surface without hassle. Additionally, the dual-band WiFi 6 and Bluetooth 5.2 connections enable me to quickly pair devices and start streaming in no time.ENUOSUMA Mini Projector:
Setting up the projector was a breeze, requiring minimal effort to connect to Wi-Fi and Bluetooth. The interface is user-friendly, making it easy to navigate through the settings and options. The auto keystone correction feature ensures that the image is perfectly aligned, and the projector can be seamlessly connected to devices like laptops, smartphones, and streaming sticks. Overall, I found the setup process to be quick and hassle-free.Conclusion
Pros:• Affordable price point
• Compact and lightweight design
• Easy to set up and use
• Good color quality in dim lighting
• Decent range of connection options including HDMI
• Limited brightness, requiring a dark room for optimal viewing
• Remote control does not come with batteries
• Built-in speakers are subpar; external speakers recommended
• Some pixelation at larger projected sizes
Overall, I find the Tecaki Mini Projector to be a solid choice for those seeking an affordable and versatile projector for casual use. It met my needs for watching shows in a small bedroom without the hassle of mounting a traditional TV. While it does have limitations, particularly in brightness and audio quality, the value it provides for the price is commendable. For casual viewers, family movie nights, or even outdoor usage, this projector is a fun little gadget that I’d gladly recommend, keeping in mind its intended purpose and limitations.
Pros:• Good image quality – supports 4K and 1080P, delivering sharp and vibrant visuals.
• Fast connectivity – Wi-Fi 6 and Bluetooth 5.2 ensure stable and quick connections.
• Portable design – small, lightweight, and easy to carry.
• Auto keystone correction – makes setup effortless.
• 180° rotation – allows projection on the ceiling, wall, or any surface.
• Works best in a dark room; daylight affects image brightness.
• Built-in speaker is decent, but for better sound, an external speaker is recommended.
Overall, the Mini Projector HY300 PRO has exceeded my expectations and is a fantastic investment for anyone looking for a reliable and versatile projector. The combination of portability, advanced features, and excellent image quality makes it suitable for a variety of uses—from movie nights at home to outdoor adventures. At its price point, it delivers exceptional value, and I highly recommend it to anyone in need of a compact yet powerful projector.
Pros:• Excellent image quality with vibrant colors and good contrast.
• Compact and lightweight design for portability.
• Easy setup with quick connectivity to various devices.
• Auto keystone correction for hassle-free image alignment.
• Good value for the price, making it accessible for many users.
• Built-in speaker quality could be improved; external speakers recommended for better sound.
• Native apps on the device can be laggy and may not connect well to the Internet.
• Requires separate accessories like a tripod or stand for optimal height adjustments.
Overall, I am thoroughly impressed with the mini projector. It delivers a fantastic viewing experience with its sharp image quality and vibrant colors, making it ideal for movies, gaming, and presentations. The compact design and ease of setup further enhance its appeal, making it a great choice for anyone seeking an affordable yet powerful projector. I would highly recommend it to anyone looking for a quality projector that offers great performance without breaking the bank.
