bigapple
As a American IDEA of Finalist Design products winner, TicWatch Pro 4G version by classical modelling of mechanical watch, and watch ring USES 316 l austenitic steel is qualitative, metallic simple sense, at the same time TicWatch Pro 4G version also has the phantom black, with different color, to meet the aesthetic needs of different users, but the overall Design from the product point of view, it may be more in line with the "straight" aesthetic, especially the author used the evaluation of the phantom black.
In terms of the specific product size, the surface of TicWatch Pro 4G version has a diameter of 45mm, a thickness of 12.6mm and a weight of 58.5g, which is only 0.01mm thicker than the bluetooth version of TicWatch Pro that was launched in May this year. There is basically no big change. Consider that the TicWatch Pro 4G version adds eSIM functionality, but it doesn't put a thicker or heavier burden on users' actual use.
TicWatch Pro 4G version supports both "smart mode" and "essential mode". The OLED display will give users a full intelligent experience of Wear OS by Google system, while the 1.4-inch monochrome LCD display will provide ultra-low-power battery life. Through the alternate display of the double-layer screen, users can not only get the full function of the smartwatch, but also have a significant improvement in battery life.
On the accessory, the TicWatch Pro 4G version comes with a magnetic charging dock and a power adapter. According to the official data, TicWatch Pro 4G version can last up to 5 days (2-day smart mode + 3-day persistent mode), while TicWatch Pro 4G version can provide more than 30 days of persistent battery life when users choose to turn on the pure "persistent mode".
Useing experience
As the first TicWatch series smartwatch running the Wear OS system (formerly Android Wear), TicWatch Pro 4G version needs to be used with the Wear OS APP. After downloading and installing, we can connect the smartwatch to the phone through scanning code or bluetooth search, and then we can "independently" use the smartwatch. On the mobile APP, we can set the dial we like and the notification function of the watch. At the same time, we can also see the storage situation of the watch. The 4G version of TicWatch Pro has about 2G storage space, which not only meets the needs of APP installation, but also allows users to store more music resources on the watch.
Summary
In product positioning, TicWatch Pro version 4G is undoubtedly a more independent smart watches, compared to before using the patch in TicWatch 2 SIM card design, TicWatch Pro new in version 4G eSIM function, absolute can bring a better experience to the user, it is better to solve the problem of the wearable devices connected to the Internet, can make smart watches and smartphone share the same number, the package in the flow and enjoy its services, bring more convenience to the user to use.
Useing experience
Summary
