Significant_Rate
- 1.1 Unboxing Experience
- 1.2 Display
- 1.3 Viewing Experience
- 1.4 Features
- 1.5 System Experience
- 2 Conclusion
| Parameter | TMY Ultra Mini Projector | Vamvo Mini Projector | KODAK Luma 150 Ultra Mini Projector |
Picture | |||
Reference Price | $149.99 | $59.99 | $219.99 |
Recommended Uses | Home Cinema, Gaming | Home Cinema | Home Cinema |
Built-In Media | Adaptor, User Manual, Remote, HDMI Cable, Cleaning Kit | Adaptor, User Manual, Remote, HDMI Cable | Remote, user manual, Speaker |
Highlight | Design Dimensions: 3.82*3.42*1.33 in Weight: 0.53 lb Battery Capacity: 5000mAh Playback Time: 3.5 hours Projection Technology: DLP Connectivity: 5G WiFi Audio: Bluetooth speaker compatible Ports: HDMI, MicroSD, USB | Bluetooth Version: 5.4 Built-in Speaker: Yes Audio Transmission: Bluetooth for audio only (no screen mirroring) Resolution: Full HD 1920x1080p Contrast Ratio: 1000:1 Max Projection Size: 170 inches (Recommended 60-100 inches) Projection Distance: 3.3ft - 16ft Power Supply: Power adapter (no built-in battery), Type-C interface (5V/2.5A) Connections: HDMI, USB, audio, and other interfaces Screen Mirroring: Wired (via data cable) | Product Type: Pocket Projector Projection Size: Up to 150” Brightness: 60 ANSI lumens Resolution: 854 x 480, supports 4K Contrast Ratio: 1000:1 Connectivity: HDMI, Micro USB, Wireless (Airplay, Miracast) Built-in Speaker: Yes Control Type: Illuminated Onboard Controls Power Source: Rechargeable Battery Battery Life: Up to 2.5 hours Compatibility Note: Cannot mirror/screencast copyrighted content from services like Hulu or Netflix; external streaming device required for such content. Gift Idea: Yes |
Unboxing Experience
TMY Ultra Mini Projector:
From the moment I unboxed the ultra mini projector, I was struck by its sleek and compact design. It fits comfortably in my hand, making it incredibly portable and easy to toss into a bag for travel. The aesthetics are modern and unobtrusive, which adds to its appeal as a device that can blend seamlessly into any setting, whether it’s a home, an office, or outdoor gatherings.Vamvo Mini Projector:
The projector's design is impressive, featuring an attractive pattern on the top and a precision array of holes on the front that gives it a unique and modern aesthetic. Weighing about 2.5 kg, it feels sturdy and well-constructed, comparable in size to popular gaming consoles like the Xbox One. This projector not only looks aesthetically pleasing but also exudes quality, making it a standout piece in any entertainment setup.KODAK Luma 150 Ultra Mini Projector:
The Kodak Luma 150 is impressively compact and lightweight, easily fitting into a pocket or travel bag. Its sleek design makes it visually appealing and practical for on-the-go use. The addition of a tripod mount at the bottom enhances its versatility, allowing for stable setups in various environments, whether indoors or outdoors. However, I found that there is a lack of a built-in lens cover, which could help protect the lens when not in use.Display
Screen Size | - | N/A - 1.7E+2 Inches | 80 Inches - 150 Inches |
Throw Distance | 5 - 0.5 Meters | 3 Feet - 16 Feet | 6 Feet - 8.5 Feet |
Contrast Ratio | > 1000:1 | 1000:1 | 3500:1 |
Maximum Resolution | 360 x 640 Pixels | 1920 x 1080 Pixels | 1920 x 1080 |
Native Resolution | 640 x 360 | 1920 x 1080 | 1920 x 1080 |
Brightness | - | - | 60 Ansi lumen |
Display Type | DLP | LCD | RGB |
Picture Enhancement | DLP | - | - |
Viewing Experience
The image quality of the projector is truly impressive for its size. With vibrant colors and sharp details, it provides a viewing experience that rivals larger models, although it's best enjoyed in dimmer lighting. I’ve used it in both daylight and ambient lighting conditions, and while it performs better in the dark, it still manages to deliver a decent picture even when the lights are low. The projector supports 1080P resolution, which enhances the overall viewing experience, making it perfect for movie nights or presentations.Vamvo Mini Projector:
The viewing experience has been nothing short of phenomenal. The resolution is sharp and clear even when projecting onto a plain white wall, creating an immersive experience for gaming and movie-watching alike. The projector can create a large image, and the picture quality remains impressive even at a distance of 10 feet. From intricate details in sports games to vibrant movie scenes, the clarity and color quality have exceeded my expectations, making it feel like a private theater experience at home.KODAK Luma 150 Ultra Mini Projector:
The viewing quality of the Luma 150 was surprisingly good for its size. In low-light conditions, the brightness and clarity were satisfactory for casual viewing, making it suitable for movie nights or presentations. However, when projecting larger images, the color accuracy and resolution began to falter, especially compared to larger projectors. Although it doesn't boast an internal operating system for streaming platforms like Netflix or Hulu, I appreciated the flexibility of connecting my devices directly, which I found to be a more reliable option.Features
Other Features | Built-In Speaker, Portable, Lightweight, Ultra Short Throw, Wi-Fi Ready | Built-In Speaker, Portable, Lightweight, Pico, Bluetooth 5.4, Bulit-in Wi-Fi 2.4G+5.8G | Portable |
Video Encoding | MP4 | H.264, H.265 | - |
Lamp Wattage | - | - | 1 Watts |
LightSource Life | - | - | 3000 Hours |
Controller Type | Button Control | - | android, vera, ios |
Control Method | Remote | Remote | App |
Connectivity Technology | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | USB, HDMI, 3.5mm Jack | USB |
Compatible Devices | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Laptop, Tablet, Smartphone | iPhone, PC, Smartphone, MAC, Android |
Wattage | 15 watts | - | 5 watts |
Mount Type | Tabletop Mount/Ceiling Mount/Floor Mount/Tripod Mount | Tabletop Mount | Wall Mount |
L x W x H | 3.78"L x 3.38"W x 1.14"H | - | 3.9"L x 3.9"W x 0.89"H |
Setting up this projector was a breeze. The user interface is intuitive, allowing me to get it up and running within minutes. It features a variety of connectivity options, including HDMI, USB, and wireless connections, making it compatible with a range of devices such as smartphones, laptops, and streaming sticks. This versatility ensures that I can use it for various purposes without hassle, whether I’m projecting from a phone or a laptop.Vamvo Mini Projector:
Setting up the projector is a straightforward process. With multiple media sockets, including two HDMI ports, I found it easy to connect my devices. The included remote control is highly responsive, allowing me to navigate through the settings without having to reach for the projector itself. The adjustment features are durable and sensitive, which is great for achieving a perfectly symmetrical projection. Overall, the setup was completed within minutes, making it accessible even for those who aren’t tech-savvy.KODAK Luma 150 Ultra Mini Projector:
Setting up the Kodak Luma 150 was relatively straightforward, especially for someone who uses their smartphone frequently. I connected it to my iPhone using an HDMI to Lightning adapter, which was much simpler than navigating the built-in operating systems of other projectors. While there were a few initial hiccups with Wi-Fi connectivity, once I accessed the Kodak network and followed the setup instructions, the projector worked seamlessly. Despite some reports of complicated setups, I found the process manageable after a little trial and error.Conclusion
Pros:• Exceptional image quality with vibrant colors
• Compact and lightweight design for easy portability
• User-friendly setup with multiple connectivity options
• Impressive battery life lasting up to 3 hours
• Affordable price point for the features offered
• Built-in speaker quality is subpar; external speaker recommended
• Requires frequent focusing during initial warm-up
• Limited functionality with certain streaming services due to copyright restrictions
• Remote control requires line-of-sight and cannot power the unit on
In summary, the ultra mini projector has exceeded my expectations in almost every way. Its combination of portability, outstanding image quality, and ease of use makes it a standout choice for anyone in need of a compact projector solution. While it does have some minor drawbacks, such as the audio quality and the need for frequent focusing, these do not overshadow the overall experience. I would highly recommend this projector for anyone looking to enjoy movies, presentations, or gaming in a convenient and high-quality format.
Pros:• Excellent design and build quality
• Outstanding resolution and picture clarity
• Impressive sound quality for a projector
• Great value for the price
• Can be a bit noisy during operation
• Limited brightness in well-lit environments
This projector is an exceptional buy for around $200, offering high-quality performance that competes with more expensive models. It delivers a large, clear image with vibrant colors and satisfying sound quality, making it a perfect choice for both casual viewing and gaming. While it has a few minor drawbacks, such as noise during operation and limited brightness in bright rooms, these issues are negligible compared to the overall value and performance. I would highly recommend this projector to anyone seeking an affordable yet high-quality home entertainment solution.
Pros:- Compact and travel-friendly
- Simple setup and reliable connections
- Good brightness in low-light settings
- Can charge via standard micro USB
- Battery life is limited to about 1.5 hours
- Built-in speakers lack quality and volume
- No keystone correction or remote control
Overall, I am quite pleased with the Kodak Luma 150. It meets my needs as a portable projector for both recreational and work purposes. While it does have its drawbacks, such as limited battery life and speaker performance, the convenience and portability of the device outweigh these issues. It's an excellent choice for casual use, especially for those looking for a compact projector without the need for extensive features. I would recommend it for anyone seeking a practical and affordable travel projector.
