Top 4 air purifiers recommended
As the urban smog becomes more serious and the PM2.5 index in various places explodes frequently, people pay more attention to air health. According to the statistics of the World Health Organization, the number of deaths caused by air pollution reaches 7 million each year. More than 90% of children in the world breathe heavily polluted air every day, and about 600,000 children die each year from acute lower respiratory tract infections caused by polluted air. Here are some air purifiers recommended for everyone.
Philips air purifier AC6608
1. Philips air purifier AC6608
High-power double-sided air inlet, 5-layer HEPA filter and coconut shell activated carbon can remove tiny particles as small as 20 nanometers. The bottom of the air purifier is equipped with a universal rolling wheel, which can facilitate the flexible movement of the living room and bedroom at home. The CADR is up to 710m³ / h, suitable for 80m² space. If you only need to use it in the bedroom, you can choose Philips AC3256 under the brand, the particle CADR can reach 400m³ / h, suitable for 48m² space use.
Granule CADR: 710m³ / h, formaldehyde CADR: 400m³ / h
Granules CCM: P4, formaldehyde CCM: F4
Filter: HEPA filter
Applicable space: 80m²
Noise level: 34 ~ 65 dB (A)
IQAir Air Purifier HP250
2. IQAir Air Purifier HP250
The IQAir air purifier HP250 has three layers of independent filter elements. While ensuring maximum filtration efficiency, each filter element can be disassembled independently to ensure maximum filtration efficiency. Under the guarantee of the three-layer super-strong filter, the CADR can reach 467m³ / h, the formaldehyde CCM can reach 3000mg, the granular CCM can reach 1013788mg, which is 84 times higher than the national standard. The strong filter makes the IQAir HP250 more stable and reliable, without frequent replacement of the filter. It is the first choice for many hospitals and research laboratories.
Granule CADR: 467m³ / h, formaldehyde CADR: 161m³ / h
Granule CCM: 1013788mg, formaldehyde CCM: 3000mg
Filter: Three layers of independent filters
Applicable space: 60m²
Noise level: 32 ~ 69 dB (A)
Blueair air purifier 480iF
3. Blueair air purifier 480iF
Blueair 480iF adopts HEPASilent multi-layer progressive filtration technology, combined with the dual technology of electronic adsorption and filter screen filtration, which greatly improves the purification efficiency. Granular CADR can reach 400m³ / h, which is suitable for use in the space of 28-48m².
Granule CADR: 400m³ / h, formaldehyde CADR: 260m³ / h
Filter: HEPA composite filter
Applicable space: 28-48m²
Noise level: 62 dB (A)
Beyon air purifier X7S (M)
4. Beyon air purifier X7S (M)
The air purifiers introduced above all need to be replaced regularly according to the use status. Finally, we will introduce an air purifier without consumable filter element Beyon X7S (M). Beyon XS7 (M) uses TPA ion wind purification technology to generate a strong plasma field at the generating and collecting electrodes. The positive ions generated by the plasma field collide with the fine particles in the air, so that the particles are charged and adsorbed, thereby achieving no Consumable filter effect. The filter has no active carbon particles, so you don't have to worry about the sour and smelly smell caused by long-term use. It can be used again after washing and drying. The particle CADR is up to 800m³ / h, suitable for 15-60m² space.
Granular CADR: 800m³ / h, formaldehyde CADR: 400m³ / h
Filter: Plasma filter
Applicable space: 15-60m²
Noise level: 63 dB (A)
Finally, you can choose the most suitable air purifier according to your needs.
