If you are in China and want to buy a home or business projector, let's take a look at the following top 6 projectors in China by now. You won't be disturbed by the shippment as we know China's delivery service is very quick and efficient.
1. XGMI H3 - the most famous Chinese projector manufacturer
Price: 5199 RMB
Specifications: Home projector DLP 3D, standard resolution 1080p, maximum display resolution 4k(3840x2160), 0.47'' DMD chip, 1900ANSI lumens, throw ratio 1.2:1, keystone correction - level/vertical±40 degrees, CPU - Mstar 6A848 quad-core 64-bit, GPU Mali-G51, Ram 3GB, ROM 16 GB, GMUI operating system, AirPlay/DLNA screen sharing, HDR 10, Wi-Fi, Bluetooth supported, 2xHDMI, 2xUSB 2.0, noise 28dB, Power 150- 180W, size 205x215x143.5mm, weight 2.75kg
2. BenQ E580 - the most popular business projector in China
Price: 6599 RMB
Specifications: Business projector DLP 3D, standard resolution 1080p, maximum display resolution 1920x1200, TI DLP display chip, 3500ANSI lumens, contrast ratio 12000:1, throw ratio 1.55-1.7, projection size 60-120'', f=22-24.1mm, scanning frequency - level±15-102kHz, vertical 23-120Hz, ROM 16 GB, Android 6.0, noise 29dB-33dB, Power 260W, size 296x221x120mm, weight 2.6kg
3. XGIMI Z6 - the cheapest Chinese projector among the top 6
Price: 2699 RMB
Specifications: Home projector DLP 3D, standard resolution 1080p, maximum display resolution 4k(3840x2160), 0.33'' DMD chip, 531ANSI lumens, throw ratio 1.2:1, keystone correction - level/vertical ±40 degree, CPU Mstar quad-core 64-bit, Ram 2GB, ROM 16GB, GMUI 3.0 operating system, noise 28dB, Power 65W, size 193x193x48mm, weight 0.973kg
4. Epson CH-TW7000 - the most expensive home projector among the top 6
Price: 10999 RMB
Specifications: Home projector 3LCD 3D, standard resolution 4k (3840x2160), 3x0.61'' display chip, 3000ANSI lumens, contrast ratio 40000:1, f=18.2-28.2mm, projection size 40-500'', noise 24-35dB, size 410x164x330mm, weight 6.6kg
5. Dangbei F3 - the best seller in JD 618 shopping festival 2020
Price: 4999 RMB
Specifications: Home projector DLP 3D, standard resolution 1080P, maximum 4k (3840x2160), 0.47'' DMD display chip, 2050ANSI lumens, throw ratio 1.2:1, projection size 30-300'', CPU Mstar6A938, RAM 4GB, ROM 64GB, extension 4TB, noise 24-35dB, size 215x215x150mm, weight 2.75kg
6. NEC CD1010H
Price: 3499 RMB
Specifications: Home projector DLP, standard resolution 1080P, 1DLP display chip, 3000ANSI lumens, contrast ratio 8000:1, manual focus, projection size 30-300'', f=21.9-24.0mm, power 240W, size 324x88x250mm, weight 2.6kg
Price: 5199 RMB
Price: 6599 RMB
Price: 2699 RMB
Price: 10999 RMB
Price: 4999 RMB
6. NEC CD1010H
Price: 3499 RMB
