AssasinK
If you are considering to buy the TCL 40S325 Roku TV, I would like to share with you the Pros and Cons of TCL 40S325 Roku TV. Then you could decide to buy it or not.
TCL 40S325 Roku TV specifications:
Inch: 40 inch
Dimensions (W x H x D): TV without stand: 35.6 X 20.5 X 2.9 inches, TV with stand: 35.6 X 22.7 X 7.2 inches.
Resolution: 1080p HD resolution
Refresh Rate: 60Hz
Motion Enhancement Technology: Natural Motion 240
Backlight Type: Direct
Streaming Services: Apple TV+, Disney+, Google Play Movies & TV, HBO NOW, Hulu, Netflix, Pandora, Prime Video, Sling TV, YouTube.
Inputs: 3 HDMI 2.0 with HDCP 2.2 (one with HDMI ARC), 1 USB (media player), RF, Composite, Headphone Jack, Optical Audio Out
Remote Control Type: standard
Work with: Alexa and Google Assistant
Audio: Dolby Digital Plus, Built-In Speakers 5 watts
Weight: 9.8 pounds with stand, 9.7 pounds without stand
Warranty: 1 year
Price: $130 on Best Buy, $200 on Amazon
TCL 40S325 Roku TV Pros:
1. The smart TV is very easy to use and the setup took about 20 min fairly quick.
2. The picture is very clear and you can set up the picture quality.
3. The smart tv channels have a lot of media to choose from if you have wifi. There are lots of cable channel apps like HGTV, TBS, etc. that offer both paid media and free media.
4. Sound quality is mediocre.
TCL 40S325 Roku TV Cons:
1. Navigating with the remote is simple.
2. The tv doesn't have Bluetooth.
3. The volume buttons on the side is really awkward to use.
4. The remote goes to sleep after a very short time requiring that I often have to push a button twice to send a command.
Inch: 40 inch
Refresh Rate: 60Hz
Warranty: 1 year
