ViewSonic PA503W vs PS502X: What’s the Difference in HDMI Features?
ViewSonic PA503W​
ViewSonic PS502X​
ViewSonicPA503W.jpg​
ViewSonicPS502X.jpg​
Price​
$399.99​
$494.87​
Business​
Education, Business​
Brightness: 4000 Lumens
Resolution: WXGA
Optical Zoom: 1.1x
Vertical Keystone Correction: 40 degrees
Input Latency: 16ms
Lamp Life: Up to 15,000 hours in SuperEco Mode
Connectivity Options: HDMI, VGA, mini USB
Resolution: XGA
Throw Ratio: 0.62 short throw
Projection Size: 100 inches from 4 feet (1.24 meters)
Lamp Life: Up to 12,000 hours in Eco mode
Connectivity Options: HDMI, USB, VGA, and more
Side-by-Side Comparison​
ViewSonic PA503W​
ViewSonic PS502X​
30 Inches - 300 Inches​
60 Inches - 300 Inches​
3.28 Feet - 38.02 Feet​
2.4 Feet - 12.3 Feet​
22000:1​
15000:1​
Display Resolution​
800 Pixels​
1920 x 1080 Pixels​
1280 x 800​
1024 x 768​
4000 Lumen​
4000 Lumen​
DLP​
DLP​
SuperColor​
SuperColor Technology​
ViewSonic PA503W​
ViewSonic PS502X​
AVC​
200 Watts​
240 Watts​
Light Source Life​
5000 Hours​
4000 Hours​
Mount Type​
Ceiling Mount​
Ceiling Mount​
Lightweight​
Short Throw​
Connectivity​
ViewSonic PA503W​
ViewSonic PS502X​
VGA, USB, HDMI​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
USB​
HDMI, USB 2.0 Type A, 3.5mm Audio​
Personal Computer​
Measurements​
ViewSonic PA503W​
ViewSonic PS502X​
11.6"L x 8.6"W x 4.3"H​
9.2"L x 12.2"W x 4.5"H​
Item Weight​
2.2 Kilograms​
9 Pounds​
Product
PROS AND CONS​
ViewSonic PA503W​
• Bright and vivid image quality
• Excellent contrast ratio
• Unbeatable price for the performance
• Long lamp life with brightness adjustment feature
• Easy to set up and mount
• Quiet operation during use
• Clear and accurate colors
• Simple keystone adjustment
• Suitable for multiple media inputs
• Resolution not at 1080p
• Only one HDMI port
This projector is a fantastic choice for those seeking a budget-friendly home theater solution without compromising on image quality. Despite its lower resolution, it excels in brightness, contrast, and color accuracy, making it a worthy upgrade from older models. The ease of setup and operation further enhances its appeal, making it an excellent option for movie enthusiasts looking to create an immersive viewing experience at home.
ViewSonic PS502X​
• Works great for golf simulator use
• Cost-effective compared to leading brands
• Easy to adjust keystone and image size
• Holds up well for travel and frequent use
• Versatile for projecting images in various settings
• Menu settings can be confusing initially
• Brightness is only okay, not exceptional
• Requires a certain distance for short throw projection
• Freezes occasionally, potentially due to older devices
• One unit experienced a failure (blowing up and smoking)
The product is a solid choice for those seeking an affordable projector, particularly for applications like golf simulators and events. While it has some usability quirks and potential reliability concerns, its performance and versatility make it a favorable option for budget-conscious consumers.
