Fujitsu launched a wearable equipment Comodo Gear which is a small cooling device around the neck and can effectively reduce the wearer's body temperature. Comodo Gear is specially provided for lease by operators in hot weather and non-air-conditioned working environment, such as construction industry and factories.
The device's principle is similar to that of commercial air conditioners, using water cooling to reduce the surrounding air temperature. Specifically, it uses the cooling chip on the device, the chip transfers the heat energy of the wearer's neck to the radiator, and then transfers the cooled water to the wearing surface through the fan and circulation pump on the wearer's waist. Even if the ambient temperature exceeds 35 degrees Celsius, it can effectively cool down.
Comodo Gear weighs only 170 and the upper waist weighs 840 grams. It is officially claimed to be able to operate normally in an environment of 5 degrees to 40 degrees. In addition to the cooling function, Comodo Gear also provides Bluetooth pairing, NFC and other communication functions, with an internal lithium battery, providing 2 to 4 hours of battery life.
