Jannyferr
A lot of Nintendo gamers encounter all kinds of weird error codes. For example, 2110-20032110-1100, what does this error code mean? Why prompt for error codes? Is it a player operation problem or a host problem? Don't worry. Let's briefly introduce the meaning of different error codes and how to deal with them so that Nintendo games can return to normal.
Nintendo Error Code: 2110-2003
This code usually indicates that the host has an error when trying to connect to the wireless router (usually before getting the IP address). This can happen if the network settings are incorrect, or if the Nintendo switch host cannot find the wireless router.
Try the following steps:
(1) Restart the Nintendo switch host
(2) Restart network device
(3) Confirm whether your wireless network account password is entered correctly
(4) Mobile Nintendo switch host is closer to wireless router
(5) Move any metal object or electronic device away from your Nintendo switch host and wireless router
(6) Create a new network connection
If the above steps still fail to solve the problem, there is a problem with the wireless router. Please try to update the firmware of the wireless router and reset the wireless router to the factory state.
Nintendo Error Code: 2811-5001
This error code usually represents a DNS setup error, a weak wireless signal, or interference with the wireless router signal.
2) Enter a different DNS address (consult your Internet service provider for the most appropriate DNS. If this error persists, try a DNS address such as 8.8.8.8208.67.222.222208.67.220.220.) ;
3) Mobile Nintendo switch host is closer to wireless router
4) Move any metal object or electronic device away from your Nintendo switch host and wireless router
5) Change the connected Wi Fi band. Try switching between the 2.4GHz and 5GHz bands
6) Restart your wireless router and other connected network devices
If the above steps still do not solve the problem, try to update the firmware of the wireless router and reset the wireless router to the factory state.
Nintendo Error Code: 2110-2200
This code usually indicates that your password is wrong when connecting to the wireless router. Please try the following steps:
1) Try to re-enter the correct network password;
2) Try to close the host to the wireless router;
3) Try to re create a network connection on the host;
4) Restart your wireless router and other associated network devices.
Nintendo Error Code: 2110-1100
This code usually indicates that the host cannot find the signal of the wireless access point saved in the Internet settings. If you are using a USB LAN adapter, it may not be installed properly. Try the following steps:
(7) Make sure the flight mode is off
(8) If you use a USB LAN adapter, check that it is installed correctly. If you have installed it correctly but still have errors, try to install it through another USB port
Nintendo Error Code: 2122-1006
This error may be caused by incorrect DNS settings in the host's network settings, or a problem with the network service provider or DNS service you are trying to use.
Please test your network connection after making any Internet settings changes to confirm that your problem has been resolved.
(2) Check the DNS settings in the host network settings, (if this setting is manual, but your network does not need this setting, change this setting to automatic)
(3) Restart network device
(4) Enter alternate DNS manually
(5) Move the Nintendo switch host closer to the wireless router, or try again later
(6) Move any metal object or electronic device away from your Nintendo switch host and wireless router
Nintendo Error Code: 2618-0516
This error code usually indicates that your network is not the best peer-to-peer (P2P), which may be caused by the NAT type of your network. Refer to the NAT troubleshooting entry to try to resolve the problem.
I hope that the above explanation of Nintendo error codes can provide you with effective help. Your favorite friends can like it or leave a message underground. You are welcome to share more useful information with Nintendo.
