Gene
Sony TV seems to be unfriendly with U disk. It always doesn't recognize my u disk.
first go back to the main menu -> application assistant
If it can be used normally, the problem is solved
If the usb flash drive is still not recognized, you need to change the format of the usb flash drive and select FAT32
