Lennon
What is the difference between laser projector and ordinary projector? We all know that the concept of laser projection has not been put forward for a long time, but the development is quite rapid, in addition to the price a little bit on the high side, other aspects of the author think it is still pretty good, so now to tell you about, laser projector and ordinary projector what is the difference?
Light source
The laser light source can have a life of more than 25,000 hours, which is at least 8 years at 10 hours per day, and at least 10 years at 8 hours per day.
In addition, the idea that the light source will slowly fade over time is true for the ultra-high pressure mercury lamps used by projectors. In theory, because of the longer life of the laser light source, the brightness will remain unchanged for a long time, but whether this is the case in practice is up to the user to compare.
Installation method
Whether it is a laser TV or a home projector, applications in the home involve an installation problem. As a result of projector projects large screen to need to project distance to assure this one principle characteristic, generally speaking, in order to ensure picture quality and the sitting room installs integral beautiful sex, most families use projector to be able to take the use way that hoisting installs.
Family projector mostly adopts hoisting method, laser TV can be placed flat on the TV cabinet.
Light resistance
The light from the laser is reflected directly into people's eyes, so they can see a clear picture. However, traditional projectors need a certain projection distance. In order to make people more comfortable to watch movies, a good projection screen mostly adopts the principle of diffuse reflection to avoid direct reflection of projected strong light. Therefore, the performance of anti-environmental light is relatively weak.
Price
The price of laser projector is higher than that of ordinary projector. The highest price of ordinary projector is $800 to $1000, while the lowest price of laser projector is $1500. The price of one laser projector is equivalent to the price of two ordinary projectors.
The above is the laser projector and the general projector of the relevant content of the difference, because the price of the laser projector is expensive now, so the budget is insufficient friends, you can buy the projector using LED light source, is also a good choice.
Light source
Installation method
Light resistance
Price
