What is the Difference between Ultra HD and 4K?
admin
Administrator
Staff member
Besides the fact that 4K is a more used term, there is one technical difference between Ultra HD (UHD) and 4K. If it is used appropriately, the 4K describes a resolution of 4096 X 2160 pixels, a resolution used mostly in digital cinemas. The UHD, on the other hand, describes a resolution of 3840 X 2160 and you can find it in TVs (16:9 ratio TVs) and is what you can actually take home. You can check our UHD demo trailers in full 4K video test.
In a nutshell, 4K is actually the wrong term for 3840 X 2160 resolution. However, it is used almost all the time and that is why the distinction between 4K and UHD has been lost. As a matter of fact, these two terms are identical for most people.
admin
Administrator
Staff member
What Makes 4K So Good?
4K adds clarity and better definition to the picture. Actually, the result is images that look beyond amazing and life-like.It is like looking through a window and not at your TV.
The best result of 4K can be experienced on large screens, which means that you will need at least 65-inch TV or bigger. According to the experts, 4K resolution improves the image quality at almost any screen size, but it is recommendable to experience it on a much bigger screen. That’s way the effect is more obvious and noticeable.
Daniel
nowadays we mostly buy smart TV with 4k resolution which brings more clear, original and bright visual effect. But some 4K TV still can not display 4k videos rightly. I wonder why.
