The 100-inch projection screen is 221.39 cm long and 124.54 cm wide, and the length and width of the screen is 16:9, which is the current mainstream screen size.
A 100-inch projection screen usually has a 16:9 aspect ratio, with a length of 221.39 cm and a width of 124.54 cm.
Among them, 100 inches refers to the length of the diagonal of the curtain. Regardless of the aspect ratio of the 100-inch projection screen, the diagonal length will not change.
16:9 is the current mainstream aspect ratio of curtains. In addition, business curtains or cinema curtains will use different aspect ratios due to different usage requirements.
The aspect ratio of commercial curtains is usually 4:3 or 16:10, and the aspect ratio of cinema curtains is usually 2.35:1.
What is the length and width of a 100-inch projection screen?
