reality
There is no difference between the LED smart light and the traditional smart light, but the LED smart light is equipped with the control system and the link communication module. The color can be changed at will, and a variety of scene modes can be made. For example, the LED smart light can be changed at will at 1600W color. You'd be wrong to think so. Whether it's to enhance the party atmosphere or improve your sleep, here are five reasons to change your light bulb. Smart bulbs are not the same as regular leds, and they're not just used to light a room like regular bulbs, which is boring. Smart lights can do much more. The reason smart bulbs are smart is because they can be controlled wirelessly through a mobile APP, which turns on many useful functions. Here are a few features of smart light bulbs.
Now only light bulbs can be adjusted with a smartphone. Install the bulb in the lamp, then the phone downloads its APP is OK, then the phone can adjust the color, brightness, switch and so on to the lamp. Some smart LED lights come out to adjust the brightness and color of the lamp, and they can also be timed on and off, and they can also play songs. The color of the light beats with the rhythm of music.
One of the basic features of smart light bulbs is the ability to dim and brighten a light bulb without the need for a dimmer switch at home. Simply screw the dimmable smart light bulb into the lamp and use the bulb's APP to darken or lighten it. Of course, it is also very important to choose the right dimmable smart light bulb, because some light bulbs will flash or make a sound when adjusted. Control the light anytime, anywhere many smart bulbs have scheduling features that allow you to control the light when you're not at home.
For example, when you are on vacation, you can turn on the lights in your home, which can reduce the probability of thieves visiting, thus improving the security of your house. This also means you can turn on the lights without having to go home, and you can turn them on as often as you need, rather than keeping them on all the time, saving on electricity bills. In addition, many smart light bulb brands can control all light bulbs through an APP. Changing the color of the light in addition, we can adjust the brightness of the light to adjust the mood, but we can do more. Many smart light bulbs can also change color. And most smart bulbs can produce 16 million colors. We can select the desired color by clicking on the color wheel in the bulb application.
Philips Hue, for example, can even change the color of the lighting at any time through Siri. Why do we need a light bulb that changes color? If you want the feel of a warm room, you can set your light bulb to golden yellow. If you want to calm down, turn your light bulb to light blue. If you're having a party, you can match the color of the light bulb to the color of the party theme. In addition, during the holiday season, such as Christmas you can change the color of the light bulb to green and red; Kwanzaa is black, red, and green or hanukkah is blue. If you don't like the color of your walls? You can use smart light bulbs to change walls to the colors you want, without having to repaint them. Play music imagine that although not every room has speakers, we can still hear music in any room, and a smart light bulb with built-in speakers can help me do just that. For example, some smart bulbs can automatically adjust the color and brightness of the light depending on the type of music you play. The only problem is that it's not loud enough to be heard if you leave the room. However, this is very suitable for children's bedrooms.
