Dangbei Projectors: X5S Plus vs. X5S MAX – Which One Should You Choose?
Dangbei has long been a key player in the projector market, known for its innovative technology and diverse product lineup that caters to different user needs. Recently, Dangbei expanded its X5 series with two new models—the X5S Plus and X5S MAX. Both have quickly gained attention from consumers. If you're considering a projector, understanding their differences will help you pick the right one.
Here’s a detailed comparison of these two models.
1. Brightness: Day vs. Night Performance
The X5S MAX features a next-gen ALPD cinema-grade laser light source, delivering an impressive 2,800 CVIA lumens. This high brightness ensures clear, vibrant images even in well-lit living rooms or with lights on. For example, fast-paced action scenes remain sharp without blurring.
The X5S Plus offers 2,000 CVIA lumens, which is lower but still perfect for dimmer environments like bedrooms with curtains drawn. Nighttime viewing or controlled lighting? No problem—it delivers crisp, colorful visuals.
2. Contrast & Picture Quality
Both models boast a 10,000:1 contrast ratio, but the X5S MAX steps up with its X Independent Light Control Chip and DynamicX Deep Black Algorithm. This combo enhances dark scenes (think "The Dark Knight") with deep blacks and vivid highlights, pulling you into the cinematic experience.
The X5S Plus also features the X chip and DynamicX, delivering strong shadow and highlight detail. Nature documentaries, for instance, look stunning with well-defined contrasts between sunlit peaks and shaded valleys.
3. Performance: Processor Power
The X5S MAX runs on the flagship MT9679 chip (1.5GHz CPU, 650MHz GPU), handling 4K HDR content and high-bitrate movies smoothly. It’s also great for AI-heavy tasks like 3D gaming or voice control.
The X5S Plus uses the MT9669, a slightly older but still capable chip found in premium projectors. It decodes 8K video and runs most apps/games effortlessly for everyday use.
4. Storage & Memory
X5S MAX: 4GB RAM + 128GB storage—ideal for multitasking and storing tons of movies/games.
X5S Plus: 3GB RAM + 64GB storage—enough for casual use but may require occasional cleanup for heavy users.
5. Auto-Focus & Keystone Correction
Both feature AI Vision 2.0 with 3D ToF sensors, enabling 0.8-second auto-focus and 6-axis keystone correction. Even at awkward angles, the image adjusts instantly—no manual tweaking needed.
6. OS & Smart Features
X5S MAX: Runs Dangbei OS 5.0 (Android 11) with ad-free instant startup, customizable UI, and advanced AI voice control.
X5S Plus: Uses Dangbei OS (Android 13) with similar perks but slightly fewer optimizations.
7. Design & Flexibility
Both have a 360° adjustable gimbal (aluminum + carbon steel) for tilt/rotation, fitting any setup—desk, ceiling, or corner.
8. Ports & Connectivity
X5S MAX: USB 3.0, HDMI 2.0 (8K support), Bluetooth 5.2—great for gaming and external storage.
X5S Plus: Standard USB/HDMI and Bluetooth—sufficient for most peripherals.
9. Price
X5S Plus: $550 (after discount from $770)—a budget-friendly 4K option.
X5S MAX: $670 (after discount from $910)—premium specs for enthusiasts.
Final Verdict
- Choose the X5S Plus if you want great value and mostly use it in darker rooms.
- Go for the X5S MAX if you prioritize peak brightness, performance, and smart features with a higher budget.
4. Storage & Memory
9. Price
Final Verdict
