Why does the projector Android 9.0 system no wireless network settings?
Nimal-ks
I tested several projectors and found that the built-in Android system is upgraded to Android 9.0 custom system, but all of them have no wireless network static IP settings, dns settings and gateway settings. Only dynamic IP can be used, which seriously affects the use without a wired network.
I just have two routers at home, one of which is used as a relay, resulting in a dynamic IP gateway connection error and unable to access the Internet. It is very troublesome. I don't know if everyone is like this, please find a solution, thank you.
