If the TV or projector keeps disconnecting when casting, it may be caused by the following reasons.
There are several reasons why the screen is always disconnected:
One is the unstable network connection. If the wifi connected to the device is unstable, it will cause the screen to be disconnected.
The second is that the casting screen is disturbed. During the casting process, the signal is interfered by others, such as router signals and Bluetooth signals, which will cause the disconnecting casting screen.
The third is that the casting distance is too far. Sometimes the distance between the casting device and the TV is too far, which exceeds the casting range, which will also cause interruption.
1. Exit the screencasting, disconnect the mobile phone from the projector and TV, and recast the screen.
2. If the screen is still interrupted after a recast, it is recommended to restart the device, restart the projector and TV;
3. You can also replace the router with stronger performance to keep the screen transmission smooth.
If you encounter screencasting disconnecting, you can try these methods to solve it.
Why does screencast keep disconnecting?
Solutions to screencast keep disconnecting
