Why my projector screen crashes when using Airplay or cast screen?
If the wifi LAN is not stable enough, it will cause the screen to flicker; Too much software running in the background of the projector, too small running memory will also cause the screen to flicker; The compatibility problem between the projector system and the screen software will also cause The projector screen crashes.
Reasons of the projector screen flash back :
1.wifi local area network is not stable enough may cause the projector screen appears flash back, because the screen is cast using wifi LAN connection, it is necessary to ensure the stability of the local area network;
2. projector software running in the background too much If the running memory is too small, the projection screen will flash back, so it is also very important to choose a projector with large storage;
3. The compatibility problem between the projector system and the projection software will also cause the projector screen to flash back.
Extended information: If the flashback is caused by the local area network, the distance between the projector and the router needs to be kept close. If it is caused by too many software running in the background, you can choose to restart or close some background applications; system compatibility problems can be restored to the factory settings. .
