Serena Anderson
Unboxing Experience
- 1.1.1 WiMiUS Mini projector:
- 1.1.2 Lisowod Projector:
- 1.1.3 EGJSG Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 WiMiUS Mini projector:
- 1.3.2 Lisowod Projector:
- 1.3.3 EGJSG Mini Projector:
- 1.4 Features
1.5
- 1.5.1 WiMiUS Mini projector:
- 1.5.2 Lisowod Projector:
- 1.5.3 EGJSG Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
| Parameter | WiMiUS Mini projector | Lisowod Projector | EGJSG Mini Projector |
Picture | |||
Reference Price | $129.99 | $149.99 | $79.99 |
Recommended Uses | Home Cinema | Home Cinema,Gaming,Indoor,Outdoor | Indoor/Outdoor |
Built-In Media | 1* HDMI Cable, 1* Lens Cover, 1* S27 WiFi Bluetooth Mini Projector, 1* Power Cord, 1* Remote Control | User Manual*1, Remote*1(No battery included), HDMI Cable*1, L02 Mini Projector*1, Adaptor*1 | User Manual, Remote, Adapter |
Highlight | 270° Built-in Stand - Custom mold, stable triangular stand, 1/4'' screw hole, supports ceiling and wall mounting. True Short Throw Projector - 0.98:1 throw ratio, projects 40~200 inches from 2.8ft to 14ft. Aspect Ratios - Supports 4:3 and 16:9. Dual Band WiFi & Bluetooth - 2.4G/5G WiFi options, Bluetooth 5.2, supports wired screen mirroring. Sound System - Upgraded for clearer sound, reduced noise. Auto Keystone Correction - Adjusts for vertical image distortion. Resolution - Supports 1080P, 15000:1 contrast ratio. Interfaces - HDMI, USB, 3.5mm audio port. Power Requirement - Not battery-powered, needs to be plugged in. Support Services - 24/7 email support, 2-year money back guarantee, 3-year repair, lifetime technical support. | 360° Adjustable & Removable Stand: DIY projection solution, easy setup in under 5 seconds Auto Vertical Keystone Correction & Electric Focus: Automatic ±30° correction, manual ±50° correction, one-touch electric focus Resolution & Display: 1080P FHD, 15,000:1 contrast ratio, 500 ANSI lumens, supports 4:3 and 16:9 aspect ratios, 70% zoom, up to 220” display Connectivity: WiFi 6, Bluetooth 5.2, HDMI, USB, 3.5mm audio port, compatible with PCs, laptops, smartphones, gaming consoles Audio: Dual 8W Hi-Fi stereo speakers Packaging & Support: Elegant packaging, designed for long-term use, ongoing support available | Swivel Bracket: 180° rotatable Projection Size: 40-130'' Resolution: Supports 1080P and 4K Best Projection Distance: 5.51ft for 60'' image Built-in Apps: Includes Netflix, YouTube, Prime Video Connectivity: Wi-Fi, Bluetooth, Miracast, AirPlay, DLNA, HDMI, USB, Type-C Projection Ratio: 0.9:1 Auto Keystone Adjustment: Yes Zoom Function: 100%-50% adjustable |
Unboxing Experience
The WiMiUS S27 Mini Projector has a compact and sleek design that is surprisingly lightweight, making it easy to transport and set up in various locations. The 270° adjustable stand is a standout feature, allowing me to project images on walls or ceilings without the need for cumbersome mounts or tripods. This thoughtful engineering makes it user-friendly and enhances the overall aesthetic of the device, fitting seamlessly into my small apartment or outdoor setups.Lisowod Projector:
The Lisowod L02 projector boasts a sleek and compact design that caught my eye right out of the box. Its white exterior with goldish trim adds an elegant touch, allowing it to seamlessly blend with my home décor. Unlike bulkier projectors that tend to dominate a space, this one feels understated yet stylish. The lightweight design makes it easy to transport, especially with the inclusion of a handy bag, making it an attractive option for various settings, from casual movie nights to business presentations.EGJSG Mini Projector:
The projector has a sleek and compact design that makes it incredibly portable. Its lightweight build allows me to easily carry it around, whether I'm heading to a friend's house or planning a movie night on my balcony. The overall aesthetic is modern and functional, with intuitive controls and a good quality feel that inspires confidence in its durability. It comes with a remote and a user manual neatly packaged, adding to the overall positive first impression.Display
Screen Size | 40 Inches - 200 Inches | 32 Inches - 300 Inches | 40 Inches - 130 Inches |
Throw Distance | 3.6 - 17.7 Feet | 4 Feet - 14 Feet | 13.12 Feet - 3.94 Feet |
Contrast Ratio | 15000:1 | - | - |
Maximum Resolution | 1920 x 1080 Pixels | 1920 x 1080 | 1280 x 720 Pixels |
Native Resolution | 1280 x 720 | 1920 x 1080 | 1280 x 720 |
Viewing Experience
The viewing experience with the WiMiUS S27 has been impressive. The 1080P resolution produces sharp and vibrant images, making movie nights feel immersive. I found that even in semi-dark conditions, the picture quality held up well, with colors popping against the backdrop. The brightness was sufficient for daytime viewing too, although darker environments enhance the overall experience. I enjoyed projecting movies onto my ceiling for a cozy bedtime experience, and the ease of focus adjustment allowed for exceptional clarity.Lisowod Projector:
The image quality of the Lisowod L02 is impressive, delivering vibrant colors and sharp details that create a mini theater experience in my living space. While it shines in dark rooms, I found it surprisingly effective even in well-lit environments. The adjustable focus and keystone correction features allow for easy customization, enhancing the viewing experience further. However, I did notice some limitations with the resolution, as the native 720p was a tad disappointing compared to the advertised 1080p, leading to some blurriness in certain conditions.EGJSG Mini Projector:
The viewing experience is truly impressive, especially for such an affordable model. The picture quality is sharp and vibrant, with colors popping even in well-lit environments. I found the 1080P resolution and HDR10 decoding to deliver a cinematic feel, and watching 4K content felt like I was in a theater. The brightness of 600 ANSI lumens is more than sufficient for my small apartment, creating a clear and immersive picture that I can enjoy during movie nights or presentations.• Pros:
- Lightweight and portable design
- Quick and easy setup with auto focus and keystone correction
- Impressive picture quality with vibrant colors and good brightness
- Built-in streaming apps eliminate the need for extra devices
- Good sound quality from built-in speakers
• Cons:
- Built-in speakers may require additional speakers for larger gatherings
- Not ideal for ceiling installation
- May need external power cables for certain devices
Other Features | Portable, Lightweight, ①After-sales: [email protected], Built-In Wi-Fi, Built-In Handle | 360 Ajustable Stand, Electric Focus & Auto Keystone, Portable Mini Size, Built In WiFi, Built In Bluetooth, Built In Speaker, 24/7 Customer Support: [email protected] | Built-In Speaker, Portable, Lightweight, Built-In Wi-Fi, Built-In Media Player |
Video Encoding | H.265 | AVC | - |
Lamp Wattage | - | 50 Watts | - |
LightSource Life | 50000 Hours | - | 50000 Hours |
Controller Type | Remote Control | Remote Control Button Control | Remote Control |
Control Method | Remote | Remote, Touch | - |
Connectivity Technology | Wired/Wireless/Bluetooth/WiFi/HDMI/USB/3.5Audio | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | Bluetooth, Wi-Fi |
Compatible Devices | Laptop, Television, Smartphone | Laptop, Gaming Console, Smartphone | - |
Wattage | 200 watts | 50 watts | - |
Mount Type | Table Mount/Wall Mount/Ceiling Mount | Tabletop Mount Ceiling Mount Table Mount Tripod Monut Wall Mount | Tabletop Mount |
L x W x H | 4.6"L x 3.9"W x 7.9"H | - | 4.49"L x 6.69"W x 5.51"H |
Setting up the projector was a breeze, and I appreciated the clear instructions that accompanied it. From the moment I plugged it in, I was able to connect my devices—such as my iPad, laptop, and a Fire Stick—without hassle. The auto keystone correction feature worked effectively to align the image, which is especially beneficial given my limited space. Although I encountered some initial difficulties with Bluetooth connectivity, I found that a quick read through the instructions made a significant difference in my setup experience.Lisowod Projector:
Setting up the L02 was a straightforward process that didn’t take much time at all. The intuitive menu and remote control made navigating through options a breeze. I appreciated the instructional videos provided, which were helpful for those who may need extra guidance. The projector’s compatibility with multiple devices via HDMI, USB, and wireless connections means I could easily connect my laptop and phone for screen mirroring. Although I had to make minor adjustments to the stand for leveling, the overall assembly was easy and user-friendly.EGJSG Mini Projector:
Setting up this projector was a breeze. I was pleasantly surprised by how quickly I could get it up and running—within just a couple of minutes! The automatic focus and keystone correction features ensured that I achieved a perfect image without any hassle. The wireless connectivity options, including dual-band WiFi, made connecting to my devices effortless, allowing me to stream content directly without needing additional gadgets. The pre-installed apps are a fantastic addition, making it easy to jump into my favorite shows right away.Conclusion
Pros:• Short throw design allows for large projections in small spaces.
• True 1080P resolution with vibrant colors and sharp images.
• Auto keystone correction simplifies setup.
• Good wireless and wired connectivity options, including Bluetooth.
• Lightweight and portable, perfect for outdoor or travel use.
• Built-in speaker quality is average; external speakers are recommended for better sound.
• Some users reported issues with Bluetooth connectivity and lag.
Overall, my experience with the WiMiUS S27 Mini Projector has exceeded my expectations. For the price point, it offers remarkable value, combining portability, ease of use, and impressive picture quality. While there are minor drawbacks regarding the sound and occasional connectivity issues, the projector’s strengths far outweigh these concerns. I would highly recommend this projector to anyone seeking a reliable and affordable option for home entertainment or outdoor movie nights.
Lisowod Projector:
Pros:• Stylish and compact design
• Easy to set up and use
• Versatile connectivity options (HDMI, USB, Wi-Fi)
• Good image quality in various lighting conditions
• Adjustable focus and keystone correction
• Built-in speakers provide decent audio
• Native resolution is 720p, not 1080p
• Refresh rate lower than expected, leading to glitchy playback
• Requires external device for streaming services like Netflix
• Plug box can get very hot during use
The Lisowod L02 projector has exceeded my expectations in many areas, especially given its affordability. Despite some drawbacks regarding resolution and refresh rate, the overall performance, compact design, and ease of use make it a fantastic choice for anyone seeking a portable projector. I appreciate the flexibility it offers for both indoor and outdoor settings, and I can confidently recommend it for those looking for a cost-effective solution for their projection needs.
Overall Impression:Overall, I am extremely satisfied with this mini projector. It has exceeded my expectations in terms of performance, ease of use, and quality. The combination of portability, excellent picture quality, and convenient streaming capabilities makes it an exceptional value for anyone looking for a reliable projector. Whether for casual home use, outdoor movie nights, or even presentations, this device has proven to be versatile and effective. I highly recommend it to anyone in search of a budget-friendly yet high-quality projector.
