XGIMI Horizon Pro 4K vs XGIMI H3s Review
geilkek
The XGIMI Horizon Pro is an exemplar 4K projector, with an incredibly sleek design and flexible projection distance. Intense brightness will ensure images are visible even in the daytime, and that HDR performance excels at night. Bar a couple of hiccups around Netflix support and power controls, and issues upscaling from SD and HD, there's plenty to like here.
PROS
  • Great 4K performance
  • Sleek, premium design
  • Affordable price
CONS
  • Upscaling issues
  • Grainy HD images
  • Lapses in streaming support
XGIMI H3S - Specs
Product Details
  • Features
    1. 3D function for powerful immersive feeling
    2. Built-in Harman Kardon Stereo speaker for superior sound quality
    3. Support up to 4K ultra HD image display
    4. Auto focus function for clear image display
  • Specification
    Brand: XGIMI
    Model: H3S
    Display type: DLP
    Native Resolution: 4K
    Brightness: 1900 ANSI Lumens
    Contrast Ratio: 5000:1
    Throw Ration: 1.2:1
    Projection Distance: 1.2 - 5.5m
    Image Size: 60-300 inch
    Image Scale: 16:9, 4:3
    Operating system: Android
    Lamp: LED
    Lamp Power: 100 - 135W
    Lamp Life: 30,000 hours
    Noise: Less than 30dB
  • Package content
    1 x XGIMI H3S
    1 x Power Cord
    1 x Power Adapter
    1 x Bluetooth Remote
    1 x User Manual
XGIMI Horizon Pro - Specs
Product Details
  • Features
    - 4K Resolution LED
    - 2200 ANSI Lumens
    - International DLP
    - System Android TV 10.0 OS
    - 2GB+32GB Auto Focus HDR10
    - Google Assistant Home Theater
  • Specification
    Display Technology: DLP
    Display Chip: 0.47" DMD
    Standard Resolution: 3840 x 2160 (4K)
    Maximum Supported Resolution: 4096*2160 @ 60Hz
    Brightness: 2200 ANSI Lumens
    Lamp Type: LED
    Lamp Life: 25,000 Hours
    Image Size: 30 - 300 inch
    Throw Ratio: 1.2:1
    Off-axis: 100%
    Projection method: Front, Rear, Ceiling Mount, Desktop
    RAM: 2GB
    Storage: 32GB
    Operating System: Andtoid TV 10.0 OS
  • Package content
    Power Adapter * 1
    Power Cable * 1
    Bluetooth Remote Control * 1
Gabe
XGIMI Horizon Pro, Disney+ works!
