XGIMI Horizon VS. XGIMI Horizon Pro review
Elena
MODEL NAMEXGIMI HORIZONXGIMI HORIZON PRO
Display TechnologyDLPDLP
Display Chip0.47" DMD0.47" DMD
Standard Resolution1920 x 1080 (1080P)3840 x 2160 (4K)
Maximum Supported Resolution4096*2160 @ 60Hz4096*2160 @ 60Hz
Brightness (ANSI lumens)2200 ANSI Lumens2200 ANSI Lumens
Lamp TypeLEDLED
Lamp Life25,000 Hours25,000 Hours
Image Size30’’ – 300’’30’’ – 300’’
Throw Ratio1.2:11.2:1
Off-axis
100%​
100%​
Projection methodFront, Rear, Ceiling Mount, DesktopFront, Rear, Ceiling Mount, Desktop
X-VUE 2.0 Image TechnologyHDR 10, HLG
MEMC
Auto Brightness Adjustment
HDR 10, HLG
MEMC
RAM2GB2GB
Storage32GB32GB
Operating SystemAndroid TV 10.0 OS
Chromecast Built-in
Google Assistant
Android TV 10.0 OS
Chromecast Built-in
Google Assistant
I/O Connection PortsDC x 1
HDMI 2.0 x 2
USB 2.0 x 2
LAN x 1
DC x 1
HDMI 2.0 x 2
USB 2.0 x 2
LAN x 1
Loop Through (Audio)Headphone x 1
OPTICAL x 1
Headphone x 1
OPTICAL x 1
WiFiDual-band 2.4/5GHz, 802.11a/b/g/nDual-band 2.4/5GHz, 802.11a/b/g/n
BluetoothBluetooth 5.0Bluetooth 5.0
Sound SystemDual 8W Harman / Kardon Speakers
DTS-HD & DTS Studio Sound Dolby
Size(HxWxD)208.4*218.4*136.2mm208.4*218.4*136.2mm
Weight2.9kg2.9kg
Elena
XGIMI HORIZON
XGIMI HORIZON
Elena
Except for the appearance, the biggest difference between XGIMI Horizon and XGIMI Horizon Pro projector is the standard resolution. XGIMI Horizon has a 1080P(1920 x 1080 )resolution while Horizon Pro is 4K (3840 x 2160).
Elena
what about XGIMI H2?
You can check out this one, Horizon and Horizon Pro definitely is better than H2 with higher brightness. The price can not be ignored though.
