XGIMI MoGo 3 Pro Projector Review: Is It Worth It for Outdoor Movie Nights?
First Impressions​
The XGIMI MoGo 3 Pro projector boasts a sleek and compact design that makes it incredibly portable, fitting seamlessly into any setting, whether it’s my living room or bedroom. Its sturdy build quality feels premium, and the thoughtful design elements contribute to an overall aesthetic that is both modern and functional. This projector doesn't just look good; it also has an elegant simplicity that blends into my home decor effortlessly, making it a stylish addition to my tech collection.
XGIMI MoGo 3 Pro Projector​
XGIMIMoGo3ProProjector.jpg​
$499.99​
Home Cinema​
User Manual, Power Cord, Warranty Card, Remote, Adapter​
Flexibility Meets Easy Usage: With a 130° built-in stand and ISA 2.0, MoGo 3 Pro can project an automatically adjusted, perfectly aligned image. Enjoy stability and uninterrupted viewing with the metal slide rail, which also protects the lens when not in use.
Designed for the XGIMI MoGo 3 Pro: The XGIMI PowerBase Stand allows you to experience high-quality entertainment in any environment.
Music Speaks Volumes: Powered by dual 5-watt Harman Kardon speakers, the MoGo 3 Pro delivers loud, crisp sound to fill your room or party. Use it as just a speaker, or pair it with Ambient Light Mode for a fun, pulsating addition to any setting.
Stream Google TV and Netflix Favorites: Watch the hottest new shows and blockbuster hits right from MoGo 3 Pro. No installation hassles – just turn on and access 10,000+ apps and 800+ free channels.
*To enhance Bluetooth connectivity, firmware updates have been automatically enabled for MoGo 3 Pro at startup.
Stunning Imagery in Any Setting: Experience vibrant, TV-quality visuals anywhere. Featuring 450 ISO Lumens brightness, 90% DCI-P3 color gamut, and 1080P resolution, MoGo 3 Pro delivers vivid colors and exceptional detail on screens up to 120 inches.
80 Inches - 150 Inches​
1 - 5 Meters​
High​
1980 x 1080 Pixels​
450 lumen​
DLP​
The viewing experience with the MoGo 3 Pro is nothing short of impressive. With 1080p Full HD resolution and 400 lumens of brightness, the images are vibrant and clear, making everything from movies to games come alive. While it performs best in darker environments, I found it still quite watchable in moderately lit rooms. The projector's ability to project a large image—up to 80 inches even in daylight—is a testament to its power, and I love how the AI handles screen adjustments, allowing for a hassle-free viewing experience.
H.264 or VP9​
65 watts​
Micro HDMI​
Hardware Connectivity​
Bluetooth, USB, HDMI​
Laptop, Gaming Console, Smartphone, Tablet​
Built-In Netflix, 2.5hrs Battery, Advanced Eye Protection, Intelligent Screen Alignment, Auto Focus in Seconds, Uninterrupted Auto Keystone Correction, Intelligent Obstacle Avoidance, Build-In Adjustable Stand, 450 ISO Lumens​
Setting up the MoGo 3 Pro was a breeze, primarily due to the built-in Google TV interface. The setup process is straightforward, requiring just one step to get started. I was pleasantly surprised by how intuitive the interface is, allowing me to navigate through apps and settings with ease. Additionally, features like automatic keystone and focus adjustments take away the hassle of fine-tuning the picture, letting me enjoy my content without fiddling around with settings.
User Feedback​
• Great, compact design
• Sturdy and thoughtful hardware
• Huge screen and long focal length
• Automatic Keystone and Focus
• Advanced settings for personalized setup
• Fast and user-friendly Google TV
• Excellent built-in speakers for size
• Fantastic and responsive customer support
• No built-in battery (requires purchasing a power base)
• Mini HDMI input necessitates an adapter for direct connections
Overall, the XGIMI MoGo 3 Pro has exceeded my expectations as a portable projector. It combines great picture quality with impressive sound, especially considering its compact form factor. While there are minor drawbacks, such as the lack of a built-in battery and needing an adapter for HDMI connections, these are easily outweighed by the projector's performance and features. I feel confident recommending this projector to anyone looking for a versatile and user-friendly entertainment solution, whether for casual movie nights or immersive gaming sessions.
Trollatopoulous
The speaker quality is pretty weak, kinda like a tiny Bluetooth speaker. The brightness is low too, so I gotta use blackout curtains when I use it. But the overall user experience is great! Just a bummer that it only has Chromecast and no AirPlay.
Wwalmarts
This projector is super simple to use once you get the hang of the screen size settings. No problems using it in my bedroom or on trips. The power bank stand is a breeze too!
Got a new projector but couldn’t stream anything on it. Definitely go for one with Google TV! My 14-year-old loves using it and it's super easy. The picture is bright and clear, even in a lit room, and the auto focus is spot on. Totally recommend it!
horizon936
Great projector, but I got a used one instead of a brand new one. Super bummed and had to send it back. Come on, Amazon, send us new stuff, not used!
I tried a different brand first, but it was a flop. Returned it and got the Mogo Pro 3, and I'm loving it! Super bright and the picture is super clear. If you're thinking about a portable projector, go for this one! You won’t regret it!
Jemma
Newer VimBox models have basically taken over this niche with better auto-keystone at a lower price. Still, the MoGo 3 Pro's picture quality holds up for its size. Did you end up buying this one?
