XXMAN98
Users who use XGIMI projector sometimes find that there will be problems with the focusing of XGIMI projector, so how to solve the problems such as abnormal intelligent correction of the picture, bad projection picture and so on? In order to ensure the horizontal and vertical standard of the picture, we will generally use the intelligent correction function of extreme meter H3. However, when this function is not good, what should be done? The following is to share with you the XGIMI projectors screen is not and focus problem solutions summary
1. XGIMI Projector auto keystone going wrong?
If there is a problem with the smart correction function of the XGIMI projector, we first need to find the application in the upper right corner of the home page and go to System Settings - More Settings - gyroscope correction. In the case of the projector being cast, we need to ensure the picture level and then do the gyroscope correction.
2. XGIMI Projector focusing function going wrong?
If the focus function of the XGIMI projector is not working, we need to go to System Settings - More Settings - Focus Correction, and then click on correction.
After entering the one-key correction page, read the description of this function and operate from 1 to 2 meters away. After entering the one-key correction function, the XGIMI projector will automatically conduct 3 focusing correction (the machine should be kept stable and not moved during the correction). When the correction is completed, you can use the remote control to operate the auto focus, and then the picture will become clear and square.
3. XGIMI Projector one-key correction function has no effect?
If the one-key correction function of XGIMI projector fails and has no effect, you can choose "Correction restore" under the menu
