Xmint
What are the most popular smart products in 2020? Here we list 3 Best smart products in 2020 which could give you the best experience of smart home. If you are thinking of building a smart home in 2020, these smart products should be added on your shopping list right now:
Smart Products in 2020: Smart door lock
smart products in 2020: August Smart Lock is easy to install and does not need to replace the entire door lock. Just replace the inner part of the twist lock door, and the original external door lock key function can still be maintained. Use low-power Bluetooth connection, the second generation supports Apple HomeKit, Amazon Echo, you can set the door lock to automatically open when you are near You can lock or unlock your phone at any time by this smart products in 2020, set the visitor ’s key, and view and record the guest ’s unlock status at any time.
If you add the smart products in 2020- August Connect or have Apple TV third generation or above, you can also remotely control the door lock through the network.
Smart Products in 2020: Smart doorbell
smart product in 2020: Ring Wi-Fi smart doorbell, 180 degree super wide-angle field of view, with night vision function, 720P high-definition camera, built-in motion detection sensor, when someone presses the doorbell or closes, it will be activated, and two-way voice function allows you to not only see visitors You can subscribe to cloud video storage for $ 30 / year and view the video at any time.
Ring Pro professional doorbell, upgraded to 1080P HD camera, dual-band Wi-Fi connection, different color panels can be directly replaced, which is also the sales champion on Amazon.
Smart Products in 2020: Smart lighting
smart products in 2020: Philips Hue series, Philips Hue's smart lighting is compatible with Apple Homekit, Google Home, Amazon Echo and many other mainstream hubs. It supports light and dark adjustment and geo-fencing. It can be said to be the most smart lighting bulb. The common A19 interface is convenient Replace ordinary bulbs in your home. The Starter Kit contains a bridge bridge, each bridge allows you to associate up to 50 bulbs. However, the Hue bulbs are not suitable for traditional dimmers.
