Mialulu
Xiaomi's new generation 4K TV stick has been released in India, it supports Dolby Vision and Dolby Atmos, and it is priced at INR 4,999. In this article, let’s take a look at the features of the Xiaomi TV 4K TV stick and how it is reviewed.
2023 Mi 4K TV Stick Specs
| Product Name | Xiaomi TV Stick 4K 2023 |
| Appearance |
| Release Year | 2023 |
| Length | 106.8mm*29.4mm*15.4mm |
| Weight | 42.8g |
| Color | Black |
| Output Resolution | 4k |
| CPU | Quad-core Cortex-A35 |
| GPU | Mali-G31 MP2 |
| RAM | 2GB |
| Storage | 8GB |
| Operating System | Android TV 11 |
| Content | Netflix, Amazon Prime Video and Youtube pre-installed |
| Wifi | Wi-Fi 2.4GHz/5GHz |
| Bluetooth | Bluetooth 5.2 |
| Video decoder | AV1, VP9, H.265, H.264, MPEG-2, MPEG-1 |
| Video Format | MKV, MPG, MPEG, DAT, AVI, MOV, ISO, MP4, RM |
| Audio decoder | DTS HD, Dolby Atmos |
| Audio Format | MP3, AAC, RM, FLAC |
| Image decoder | JPG, BMP, GIF, PNG |
| Ports | HDMI x 1 Micro USB x 1 |
| In the box | Xiaomi TV Stick 4K x 1 Remote control x 1 Power adapter x 1 User manual x 1 HDMI Extender cable x 1 |
2023 Mi 4K TV Stick Appearance
Mi 4K TV Stick is a black cuboid. It is very small, like a USB flash drive. Its body depicts the Xiaomi logo and comes with an HDMI interface. How to use it? Just plug it into your TV, select the corresponding HDMI signal source, and you can use it immediately, which is very convenient.2023 Mi 4K TV Stick System
The Mi 4K TV Stick is powered by Android TV 11, comes pre-installed with the Google Play Store, and provides access to over 10,000 apps, and over 400,000 movies and shows.2023 Mi 4K TV Stick Features
The device supports Dolby Vision and Dolby Atmos can also use the Google Assistant voice assistant and has built-in Chromecast, so users can stream their favorite shows from their phones, tablets, or laptops to their TVs.2023 Mi 4K TV Stick Hardware
In terms of hardware, the 2023 Xiaomi new generation 4K TV stick is equipped with a quad-core Cortex A35 processor, equipped with ARM Mali-G31 MP2 GPU, 2GB memory, and 8GB storage space, supports dual-band Wi-Fi 802.11 ac and Bluetooth 5.0, and is equipped with an HDMI interface and a Micro USB port.2023 Mi 4K TV Stick Connectivity
The 2023 Mi 4K TV stick device is paired with a 360° Bluetooth + IR remote control, has a dedicated voice assistant and a streaming media button, and comes pre-installed with Netflix, Amazon Prime Video and Youtube.
