SuperSonic was once a popluar brand in electronics manufacting. If you are choose a new small size TV based on brand, let's check on the SuperSonic. For those who are looking for a 24-inch TV, there is the SuperSonic SC-2412.
What are the features of the 24-inch TV SuperSonic SC-2412?
1. It has a built-in DVD player which allows you to play your DVDs without any other equipment and freely use your Firestick or similar hardware to browse thousands of channels and apps such as Netflix, Hulu, HBO, Showtime. But you shall connect with the HDMI, USB, and AC/DC ports.
2. AC/DC Compatibility. Convenient for RV owner.
3. With the available PC input feature you can use your TV as a computer monitor. The screen size and resolution make for a great PC experience!
4. USB input allows you to upload photos amd musics on the big screen.
5. SD input also allow you to enjoy your photos amd musics on the screen
What are reviews of the 24-inch TV SuperSonic SC-2412?
The actual TV & DVD works well. Since it is only 24-inch, you can use it as a pc monitor. The sound of the TV itself is low. Sometimes the usb port can't read the stick. It only have 1 HDMI ports which would be inconvenient if you want to connect other devices. It don't support bluetooth as well. If you decide to buy this 24-inch TV, don't forget ot ask for warranty.
SuperSonic SC-241 Specifications:
Item Dimensions: 22.32 x 6.69 x 14.84 inches
Item Weight: 9.00 lbs
Model Year: 2015
Screen Size: 24 inches
Display Type: Sleep Timer Function Multi Language On Screen Display Power Source
Refresh Rate: 5 hertz
Resolution: 1080p
Brightness: 250cd/m
Contrast Ratio: 1000:1 (dynamic)
Response Time: 5ms
Viewing Angle: 170 (H), 160 (V)
Power Input: DC 12V-3A (Cord Included)
Total HDMI Port: 1
Input Terminals: Cable/Antenna RF, USB, Audio/Video,Component Input (HD Ready), YPbPr, VGA (Computer Monitor), PC Audio Jack, HDMI Input(s)
Output Terminals Compatible: Headphones & Coaxial Out Wall Mountable Design, VESA Compliant Full Function Remote Control
Price: $177 on Amazon
Model Year: 2015
Resolution: 1080p
Brightness: 250cd/m
Response Time: 5ms
Total HDMI Port: 1
