LouiseWinner
Although most people prefer 55-inch at least when buying a TV, 32-inch TVs are still worth buying. For example, you can put it your small dormitory, connect it to your computer without large space occupancy. Also the smaller the TV size, the cheaper it will be. Here I recommend best 32-inch TVs in 2020 worth buying.
VIZIO D32X-D1 ($179.99)
Screen size: 32-inch | Tuner: N/A | Resolution: 1920 x 1080 | Panel technology: LED | Smart TV: VIZIO Internet Apps Plus | Curved: No | Dimensions: 505 x 733 x 184 mm
VIZIO's small screen has a lot going for it – including a full 1080p resolution and an app tray full of the most popular streaming services (including Netflix, YouTube and Hulu). We'd recommend plugging in some speakers if you can, as the integrated ones aren't great. If you're looking for something smart, small and affordable at a 32-inch size, VIZIO's small screen is highly recommended.
Samsung UN32M5300 ($219.99)
Screen size: 32-inch | Tuner: NA | Resolution: 1920 x 1080 | Panel technology: LED | Smart TV: Smart Hub | Curved: No | Dimensions: 29.2 x 18.5 x 5.7 inches
It offers full 1080p images and its Tizen operating system for a price that most folks can afford. This grants access to loads of apps, and the TV's built-in Wi-Fi stops you from having to plug it into your router. We have to remind you that this TV have only 2 HDMI ports.
TCL 32S305 ($189.99)
Screen size: 32-inch | Tuner: N/A | Resolution: 720p | Panel technology: LED | Smart TV: Yes (Roku TV) | Curved: No | Dimensions: 28.9" x 19.2" x 7.2"
It was affordable, offered built-in Roku TV and decent picture quality considering the fact that it was limited to 720p. This tv was one of the best-selling 32-inch TVs in 2017.
Sony KDL32WE613 ($299.99)
Screen size: 32-inch | Tuner: Freeview HD | Resolution: 1366 x 768 | Panel technology: LCD | Smart TV: Cloud TV | Curved: No | Dimensions: 490 x 731 x 187mm
It supports HDR, usually only seen in much larger, more expensive TVs. HDR isn't equal across sets as it relies on a screen's contrast and brightness, but it will let you squeeze more out of a top-end Netflix or Amazon Video subscription, or your favorite console games. The TV also offers recording over USB, Wi-Fi and access to BBC iPlayer, YouTube and a fistful of other apps.
The prices are for reference only. You can choose one from the above 32-inch TVs at affordable price. Hope this article is helpful for you.
