akagi1945
What is your best choice of home entertainment for 2020?
Before people move to a new home or change for a new TV, you may always have the thought: how can I make my home entertainment life more fabulous with the right electronics? The first idea is to have a home theater that integrates audio and video with an immersive experience. At the same time, you can find many suggestions like a big-screen TV or home project.
Make the right decision is not easy before we know the advantage of each, however, based on the same function, the home projector has more
benefits than TV as follow:
1.One of the most apparent advantages of the projector is the relative cost-effectiveness of large scale screens.
For example, an 80 inch TV costs several thousands of dollars, but an 80-inch screen is general for mainstream price projector, and even a 4K class home
projector can cost less or similar price level that if you care about the resolution.
2. Better eye protection for users
Projection image is in the form of wall or fabric diffuse reflection, comparing to the direct light source from television. Your eyes feel more comfortable in the same brightness.
3.Save space & flexible solution
In combination with the way of suspended ceiling and side projection,
the layout of the Home projector is simple and does not take much space. And you can quickly move to another room flexible, depending on the needs.
As for the maintenance problem that many people are worried about, the
new generation of home projectors use LED and DLP technology, which supports a full life of 30,000 hours. Even if you think about eight hours of daily viewing, it is enough to last more than ten years. With a power consumption within 120W, you can see the product has reached a very high level of maturity.
Especially in the past two years, the development of the smart home projector has made it more popular than traditional TV. As you can see, no matter AI or IoT or other advanced elements, the display of intelligent home projection is no worse than that of smart TV. Meanwhile, the smart home projector is inherently smaller in size, more significant in the image, portable, and innovative in the industry, it's much easier to reach younger consumers, as evidenced by two years of incremental smart projector data.
Same as smart TV, only the brands that have survived the industry's big waves can offer more user-friendly products to consumers. In 2009, Dangbei became a well-deserved dark horse in the industry with his model F1, and let's have a look at what breakthroughs with the latest launch F1C.
Appearance
From the modeling point of view, Dangbei smart home projector F1C designs with classic space gray ABS plastic material and dark gray mesh combination. Flat and Slim design is compatible with both home and business style. No matter keeping at home or in the conference room is fantastic and harmonious.
When you get close to the Dangbei smart home projector F1C, your attention can focus directly on the Lens at first glance. It adopts sapphire glass and can achieve dynamic thermal compensation of the Lens. With a Sealed Silica Gel to protect against the dust, a significant guarantee of light permeability.
Back to the real demand of home movie, Dangbei Smart home projector F1C offers 1300 Ansi Lumens brightness to ensure the daily use of users.
Move Your eyes to the left of the projector, and you can find the dual TOF laser module and CMOS camera module under the lens cover. The Dangbei smart home projector F1C designs dual algorithms to achieve laser autofocus, and this autofocus can be instantly precise, fast, and does not interfere with the user's viewing experience. Combined with the application of ICCHIPS and accelerometer, the F1C can also achieve quick and insensitive image correction to deal with a variety of complex use scenarios.
The side is of fence design with the structure of ventilation on one side and heat dissipation on the other side. At the same time, Dangbei smart home projector F1C using a shorter and thicker pure copper heat pipe and a larger area of the heat sink. The reconstructed design provides more efficient heat dissipation in lower fan noise. The sound of the fan is barely audible, and the heat dissipates well, keeping the temperature below 40 degrees that reduces the damage to the lens and the product.
The back side is with power switches and a row of ports. From left to right, you can see headphone Jacks, Lan ports, HDMI2.0 ports, dual USB3.0
ports, and power ports. With the USB 3.0 interface, Dangbei Smart home projector F1 ensures a smooth data transfer experience for external
devices.
After power on, the power key lights up the red indicator light. Switch to the Bluetooth speaker mode lights up the blue light.
The top of the Dangbei smart home projector F1C is clean and straightforward.
The bottom of the device is also simple, with detachable screw pads at
four corners, threaded ports with brackets in the center, and tabs with necessary product information.
The classic design consists of the natural side button of remote control.
UI Content
The UI design and content of the Dangbei smart home projector are both mainstream and personalized. The F1C's Dangbei OS updates to provide a more user-friendly human-computer interaction experience.The massive resources online at the same time give users significant freedom to install. Below you can see the specific performance of the Dangbei smart home projector F1.
The user interface of Dangbei OS still follows the classic model. Each navigation item supports user-defined addition, subtraction, and sorting. Users can organize the UI desktop according to their preferences.The settings menu pops up on the right, and the Keystone correction is a highlight of the flagship update. It uses multiple sets of ToF lasers,
accelerometer, CMOS camera modules, and an internal ICCHIPS for image
processing to capture information. When the projector changes any angle, it quickly perceives,synchronized adjust the screen, and display a square screen for users at all times.
The Dual ToF and CMOS camera also allow for faster and more accurate
focusing. When real-time focusing is enabled, the projector automatically
senses the concentrate of the current image.It achieves fast clarity with a fantastic viewing experience.
Long Press the remote control side keys, you can have an automatic focus on the current page quickly with significant effect.
Appearance
devices.
UI Content
