Let's look at these three small affordable portable projector comparisons between Anker Nebula Solar Portable vs BenQ GV30 vs XGIMI MoGo Pro. They are almost in the same price range and function. Check the comparison table and make your choice.
The Anker Nebula Solar Portable is the most expensive of the three projectors, priced at about560$ while the other two projectors are both 499$. Weighing in on whether you want to pay $60 more? See what features appeal to you.
The Anker Nebula Solar Portable is the smallest and looks more like a TV box. BenQ GV30 has an unusual design, with a shape rarely seen on the market. Do you like this unique style? The XGIMI MoGo Pro is the traditional type of projector, which is a column with no angles.
Both the Anker Nebula Solar Portable and the XGIMI MoGo Pro are 1080p projectors with the sharpest displays of the three. But the BenQ GV30 sounds a little better with its 4W output, while the other two only have 3W.
Also, in terms of portability, the Anker Nebula Solar Portable is the smallest and has the longest operating time. Overall, these three projectors can support a 2+ hour movie with no problem.
Finally, of these three projectors, only the BenQ GV30 supports AirPlay Mirroring connectivity, however, they all support Chromecast connectivity. Please consider carefully, is your device smart enough to connect via AirPlay? If so, go for the BenQ GV30.
Anker Nebula Solar Portable vs BenQ GV30 vs XGIMI MoGo Pro Price
Anker Nebula Solar Portable vs BenQ GV30 vs XGIMI MoGo Pro Appearance
Anker Nebula Solar Portable vs BenQ GV30 vs XGIMI MoGo Pro Features
