BenQ has now released the GV11 portable projector, starting at $279. What are the features of this projector?
The BenQ GV11 portable device is battery powered and provides up to 160 minutes of video or 240 minutes of audio playback. The device is compact, weighing 2.14 pounds, measuring 4.5 x 6.0 x 5.5 inches, and can operate quietly at 23 dBA.
BenQ GV11 Projection Functions
The lens of the BenQ GV11 can be rotated for a wider projection angle and supports automatic vertical keystone correction. It has a physical resolution of 480p, a brightness of 200 ANSI lumens, and a throw ratio of 1.3.BenQ GV11 Smart Features
The GV 11 has a built-in 5W sound system, is equipped with Android TV 10 operating system, supports Google Assistant voice command control, and can connect devices via HDMI and USB-A.The BenQ GV11 portable device is battery powered and provides up to 160 minutes of video or 240 minutes of audio playback. The device is compact, weighing 2.14 pounds, measuring 4.5 x 6.0 x 5.5 inches, and can operate quietly at 23 dBA.
