BenQ GV30 Rotating Portable Projector
Linsesa
BenQ GV30 Rotary Portable Projector is now on the market, with a teardrop-shaped design, 720P resolution + 2.1-channel audio, priced at 3999 yuan.
This projector features a portable design with a built-in battery that supports 2.5 hours of battery life. It has a lens that can rotate freely at 135 degrees, and can be adjusted with a magnetic base. In terms of speakers, it is equipped with 2.1-channel audio, including two 4W tweeters and an 8W woofer.
The BenQ GV30 projector can achieve 720P standard HD projection, 98% Rec 709 color gamut, and 300 lumens of brightness. It can project 100 inches at a distance of 2.7 meters, it supports wireless projection, and the interfaces include HDMI, USB-C, etc. In addition, this projector has a Bluetooth speaker mode, which can be used as a portable speaker alone.
