Can USB be converted to HDMI? Yes, USB can be converted to HDMI. The USB3.0 interface supports the output of 1080p resolution images, and the USB2.0 interface supports the output of 800×600 resolution images. The output device can be converted from the USB interface to the HDMI interface to the input device.
The output device is converted to the HDMI interface through the USB interface, and the picture is input to the display device. At the same time, the high-end USB to HDMI adapter can output audio through \HDMI at the same time, and the high-end adapter has a built-in audio chip. Note that the USB3.0 interface supports outputting 1080p resolution images, and the USB2.0 interface supports outputting 800×600 resolution images.
If you want to convert USB to HDMI, then you need to use a USB to HDMI adapter. The USB to HDMI adapter supports macOS, Windows, Android and other devices.
