translated from chinese
Dangbei D series new product D5X is on the market. Compared with the previous generation, Dangbei D5X has a lightweight body, which is more in line with the needs of modern young people. At the same time, the configuration has been further upgraded. Specifically, the actual use of this projector How effective is it? Let's find out through the actual measurement experience, and see what kind of charm the thin and light projection has.
01/Dangbei D5X unpacking
Friends who have seen Dangbei U1 before opening the box should have discovered that recently Dangbei Projector has been very careful in the outer packaging of new products, and the unpacking design will add a sense of ceremony. This time D5X The same goes for the packaging.
The packaging of Dangbei Laser Ultra Short Focus U1 adopts a file box design, while Dangbei D5X adopts a movie allegro design. Turn on "Allegro", immediately start the home theater, and enjoy your own movie-watching moments.
In addition, there are stickers and thank you cards in the box of Dangbei D5X, and the stickers happen to be the theme of the Year of the Rabbit in the lunar calendar.
02/ Appearance of Dangbei D5X
After opening the package, the first sight I saw of Dangbei D5X mainframe reminded me of the Mac Mini with added internal power and more domineering. From the perspective of looking down, the D5X is indeed very similar to the Mac Mini. I believe that the performance of the D5X should not be underestimated just like the Mac Mini.
After a series of observations and touches, it is deduced that the D5X should be made of skin-friendly and delicate space gray plastic material, decorated with metal and glass. There is a long piece of glass on the front lens part, which adds a bit of quality to the appearance of the product. The main function of this piece of glass is to protect the projection lens, ToF module and camera.
In terms of size, the bare D5X is 195*195*47.5mm, only the thickness of a book; the weight is less than 1kg, which is only the weight of a cup of latte. Such a thin and light design makes it very convenient to move and carry even for female users.
The metal honeycomb screen on both sides of the fuselage has dts HD and Dolby Audio screen-printed. It seems that Dangbei D5X can support Dolby and DTS. In the test playback section, we will also try to play different sources to test D5X. We will discuss the details later. Let's talk again.
Turning to the back, it can be divided into three modules from left to right, power button, cooling vent and expansion interface. The interface is equipped with HDMI2.1 (supporting eARC), USB2.0, 3.5mm Audio and DC power interface, which can be expanded to connect game consoles, audio equipment, and U/hard disk. At the same time, the power button has a single-color LED indicator light, which is convenient for users to judge the status of the projector. The LED light is on when it is plugged in and not turned on; after it is turned on, the LED light will go out.
The thin and light design is not only reflected in the projector, but also in the remote control and power adapter. The remote control of the D5X is a new long-handled Dangbei remote control. The back adopts an arc-shaped design, which enhances the grip, as if holding a lightsaber. The adapter is an integrated wall power adapter, small in size, easy to store and more portable.
This is the end of the appraisal of the appearance part. The appearance design of Dangbei D5X and its accessories can be described as "lightweight". The pursuit of exquisite and convenient products also confirms the slogan of D5X light, thin and extraordinary.
03/ Dangbei D5X system After
talking about the lightness and thinness, let’s take a look at the extraordinary features of D5X.
I believe that the vast majority of users should be most concerned about film and television resources for home smart viewing equipment. The built-in Dangbei OS of D5X brings together many film and television content such as Mango TV, iQiyi, Youku, Tencent, etc., which can fully meet the needs of users to watch movies at home. If you want to see a new album, you can get the result feedback through the whole network search function, and you can get it right away. Moreover, it is Dangbei's only function to search for movies on the whole network. While searching for movies, it also provides application downloads for playback sources, which saves you the trouble of finding movies.
Magic Screen
Just listen to the words Magic Screen, you must think that this is a function similar to screen projection. It is not. Magic Screen can be understood as a function that is controlled by the mobile phone as the Beijia app, and the projector responds in real time. You can control the large screen projection with your mobile phone. The point is that it supports remote same-screen control, which is suitable for remotely assisting the elderly and children to play TV. When the main user of the projector is working in the company, and the elderly at home want to watch TV, they can use the magic same screen function to play for the elders.
Ambient Screensaver
Ambient is an application we found in the application center, and it is pre-installed. After launching the application, we found that this is a tool software that can be set as a screen saver. This software has a lot of theme wallpapers, which can display a very atmospheric home scene on the wall through the projected light and shadow effects. At the same time, you can also choose a mask effect in the atmosphere setting, which can create an atmosphere background wall for shooting.
of the remote control The side buttons of the Dangbei remote control are inherited from the first Dangbei projector. There are two side buttons on the right side of the D5X remote control, one for quick auto focus and the other for In the outgoing shortcut center. Call out the autofocus through the side button, which is easier to operate than other projectors. Among the projectors I know, many projections still need to enter the settings to arouse the focus, which is much more cumbersome than Dangbei projection.
![1.gif](https://tyimg.touying.com/static/image/hrline/1.gif)
![105954mrwvg8p2r141t0tw.png!w800](https://tydata.touying.com/forum/202212/26/105954mrwvg8p2r141t0tw.png!w800)
![105956seamtoj9jlm59cbj.png!w800](https://tydata.touying.com/forum/202212/26/105956seamtoj9jlm59cbj.png!w800)
![105959ei8zzrxxil8mr8bz.png!w800](https://tydata.touying.com/forum/202212/26/105959ei8zzrxxil8mr8bz.png!w800)
![110001rxp9iwppn02e6c9m.gif](https://tydata.touying.com/forum/202212/26/110001rxp9iwppn02e6c9m.gif)
![110002oey3yxpz6ev1zyip.png!w800](https://tydata.touying.com/forum/202212/26/110002oey3yxpz6ev1zyip.png!w800)
![110004s809hu84kthka4f8.png!w800](https://tydata.touying.com/forum/202212/26/110004s809hu84kthka4f8.png!w800)
![110006qtdttez1jj12wmht.png!w800](https://tydata.touying.com/forum/202212/26/110006qtdttez1jj12wmht.png!w800)
![110009u3v6vjmr7f2jq3fq.png!w800](https://tydata.touying.com/forum/202212/26/110009u3v6vjmr7f2jq3fq.png!w800)
![110011fgbz86g8dxzb85g8.jpg!w800](https://tydata.touying.com/forum/202212/26/110011fgbz86g8dxzb85g8.jpg!w800)
System home page
![110012mecaef26vfhjbhfa.jpg!w800](https://tydata.touying.com/forum/202212/26/110012mecaef26vfhjbhfa.jpg!w800)
Search the whole network
But for me, film and television resources cannot reflect the excellence of a TV system. I will pay more attention to system experience and product functions, and Dangbei OS, which has always paid attention to user experience, really supports many interesting and practical functions. For example, Magic Screen, Dangbei Atmosphere Screensaver, remote control side buttons and Findme remote control retrieval, etc. Let me introduce a few functions that I personally find very useful, and talk about its usage scenarios.Magic Screen
![110013o77z9fp88sscgl8g.png!w800](https://tydata.touying.com/forum/202212/26/110013o77z9fp88sscgl8g.png!w800)
Ambient Screensaver
![110015yi9vqxwoy1qclxzi.jpg!w800](https://tydata.touying.com/forum/202212/26/110015yi9vqxwoy1qclxzi.jpg!w800)
atmosphere app
The side buttonsof the remote control The side buttons of the Dangbei remote control are inherited from the first Dangbei projector. There are two side buttons on the right side of the D5X remote control, one for quick auto focus and the other for In the outgoing shortcut center. Call out the autofocus through the side button, which is easier to operate than other projectors. Among the projectors I know, many projections still need to enter the settings to arouse the focus, which is much more cumbersome than Dangbei projection.
![110016elizvd42v1t4tpnz.jpg!w800](https://tydata.touying.com/forum/202212/26/110016elizvd42v1t4tpnz.jpg!w800)
