DreamFair HY300Pro vs ENUOSUMA Mini vs CiBest Mini Projector - two of them hide their real brightness
Nadia
The thing that stopped me on these three listings was the brightness claims. DreamFair is the only one that actually prints a number: 180ANSI. The other two say "1080P Support" and "Full HD" in huge letters and then never tell you how many lumens you're getting. That silence is the whole story here, because all three are forty bucks and forty bucks buys you a toy projector, not a home theater.
Let's be honest about the "4K" in the DreamFair title. A $37.69 projector does not do 4K. 180 ANSI lumens is a real, modest figure, and at least they admit it instead of pretending. The ENUOSUMA at $39.98 is the one that leans hardest on software - built-in Prime Video, YouTube and Hulu, no stick required. For a bedroom or a kid's room where you just want to cast something without a Fire Stick dangling off the back, that's genuinely the selling point. The CiBest at $39.99 is the "safe generic" pick: 1080P support, 30-200 inch, recommends 60-130 inches, and mentions uniform edge illumination, which is the classic weak spot on cheap LED projectors.
Ratings are basically a dead heat on the first two - DreamFair 4.4 from 1186 ratings, ENUOSUMA 4.4 from 1237 - and the CiBest sits at the same 4.4 but from only 590. More ratings at the same score usually means the score is more trustworthy, so I'd weight DreamFair and ENUOSUMA slightly higher on that alone. Purchase volume is close too: 400+ bought in the past month for DreamFair, 500+ for each of the other two.
Where each one fits. DreamFair: you want the cheapest of the three and you actually care that someone published a brightness figure, even a small one. ENUOSUMA: you want apps built in and you're fine never plugging in a streaming stick. CiBest: you want the plainest, least marketing-heavy option and you'll accept that they won't tell you the lumens. Skip all three if you're expecting anything watchable with the lights on or in a bright room - 180 ANSI and whatever the other two are hiding will wash out fast, and none of these list a real contrast ratio or refresh rate, which tells you what tier you're in.
My gut says the CiBest is the weakest value of the three: same price as ENUOSUMA, fewer ratings, no apps, no brightness number. Between the other two it comes down to whether built-in streaming beats a stated lumen figure.
What I actually can't figure out from the listings: does the ENUOSUMA's built-in app store let you install anything you want, or are you stuck with the handful of apps they preloaded? If it's locked down, that "no stick needed" pitch falls apart and I'd just take the DreamFair. Anyone using it?
What the listings say (as of Sep 25)
SpecDreamFair StoreENUOSUMA StoreCiBest Store
Price$37.69$39.98$39.99
Amazon rating4.4 (1186 ratings)4.4 (1237 ratings)4.4 (590 ratings)
Bestseller rank#17#14#19
