mtn328
Ecovacs T5 Power is good-looking and has a good cleaning capability (whether it's cleaning or wet towing). Through APP, Ecovacs T5 can realize functions that truly adapt to the scene, such as selection sweeping, ground sweeping, virtual wall, zoning sweeping and multi-layer map memory.
Smart voice function, the design advantage of the roller is like the car tire, the outer soft rubber will not scratch the floor, the elastic design can ensure climbing, the official data is across the slope threshold of 2cm. There is a water tank on the buttocks of the robot, the bottom is used to mop the floor of the cloth, the volume of the water tank is relatively large.
Ecovacs T5 Power Cleaner is equipped with filter screen, sponge and washable high efficiency filter screen, which can carry out triple filtration system to avoid the discharge of micro dust. The detail processing is still very good. Equipped with Smart Echo ultrasonic carpet recognition is also a highlight of Ecovacs T5 Power, which can sense the ground environment. When the carpet is in wet towing state, it will automatically go around and vacuum the floor automatically. Built-in 5200mAh large battery, the capacity of greater endurance, a full charge of about 4-5 hours, full charge can be used for about 200 minutes. Moreover, when the power is lower than 15%, it will be recharged automatically, which is very convenient without manual intervention. The Ecovacs T5 Power uses a new Smart Navi Smart navigation system, along with 38 sensors on its fuselage, to allow a detailed scan of the surrounding environment to map out the relevant cleaning route.
