Jemma
The spec sheet and the description of the new ELAC DBR63 disagree about where the port is, and for a bookshelf speaker that is not a small thing. The ecoustics write-up says the DBR63 moves to a rear-firing circular bass-reflex port, and warns about placement near walls. The specification table in the same piece lists the port as front-firing dual-flared. One of those is wrong.
It matters because the outgoing DBR62 had a front-facing slot port, and that was a big part of why people recommended it for shelves and desks and anywhere tight against a wall. If the DBR63 really is rear-ported, the easy-placement argument goes away and it becomes a speaker that wants stands and some space behind it.
The rest of the changes are clear enough. $899 a pair. The soft dome is gone, replaced by a 1-inch aluminum dome with a phase plug and waveguide. The 6.5-inch woofer is a new aramid fiber cone with no dust cap, the crossover is at 2,500Hz, and the cabinet gets rounded edges and a stitched synthetic leather top. Five finishes, including a green one.
Numbers for amp matching: 86.5dB sensitivity, 6 ohms nominal with a 4.5 ohm minimum at 230Hz, and a quoted 49Hz to 34kHz at -3dB. So not hard to drive, but not efficient either. A small AVR will do it; a tiny class D desktop amp may run out of room.
My hesitation is the tweeter. The soft dome in the DBR62 was forgiving with bright receivers and bad streams, and aluminum domes are less polite about both. Until someone posts a photo of the back panel and a listening-window measurement, I would not order these blind as a DBR62 replacement.
