Fortnite Guide Chapter 2 season 2: Secret mission of the creative mode, week 14
akagi1945
You are now used to it, each time you change the creative mode menu, a secret challenge appears on Fortnite . This one this week is also particularly well done and if you want to try it for yourself, we obviously do not recommend reading these lines.
ACCEPT QUEST
The first step will be to accept the quest in the main menu of this creative mode. For this, nothing too complicated, go straight, go behind the climbing plant and you will see the statement of this challenge. Then head to the table and accept the challenge.
FIND THE KEY
You will then have to go to the east island with a large house. Head to the door and go through. Indeed, it is fake and you should find yourself directly in the house . There, you will be told that the key must be found in the cellar.
Get out of the house and head to your left. You will see a small island below, go there. There you will find the famous cellar of the house. Behind the barrels at the bottom right, crouch down and go into the secret passage where you will find the key.
FIND THE FLOWERPOT
To find the second relic, go to the main building at the end of the island and take the passage in the middle of it. You will then find a springboard. Use it to go to the balcony on the right side of the house . You will then arrive at the flower seller who tells you that there is a special object in the back room.
To find it, go back to the springboard and go along the wall corresponding to that of the flower seller. You should then find a secret passage hidden by climbing plants . Borrow it and you can take the flowerpot.
FIND THE CHEST
The third relic is in the island to the southwest of the map and you will have to walk a bit to reach it. Then use the crates against the house to go up on the roof and find the chest where the last relic is hidden.
FINISH THE CHALLENGE
To finish this challenge, go to the island to the south of the map and climb onto the roof again. Go behind and drop onto the balcony below. It will then be sufficient to use the telescope to teleport to the final island.
