- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
The Hisense PX3-PRO isnt meant to be portable as its quite heavy and lacks an integrated battery, so you need to plug it in. The projector has a feature for auto keystone correction, but it requires you to go through a few extra steps, such as scanning a QR code and uploading a picture of the projected image. Furthermore, it doesnt work well, so ultimately, youll most likely need to adjust the image geometry manually, and it also doesnt have autofocus.It doesnt have an adjustable stand, but it does have adjustable feet. It has a 50W Harman Kardon speaker system, so you won't need to worry about connecting it to a soundbar if you move it.The Hisense PX3-PRO uses a laser light source, which requires no maintenance and will last for 25,000 hours or more, according to the manufacturer. Its not a true 4k projector, as it uses pixel shifting to create a higher-resolution image. This offers better quality than a pure 1080p projector but isnt as good as a native 4k projector.It's an Ultra Short Throw (UST) projector, so it can project a 90-inch image at a distance of 6.6 inches and up to a 130-inch image at a distance of 14.3 inches, which is significantly closer to the wall than its predecessor, theHisense PX1-PRO.
| Parameter | Hisense PX3-PRO |
Reference Price | $3297.97 |
Recommended Uses | Entertainment, Education, Home Cinema, Gaming, Business |
Built-In Media | Projector, User Manual, Power Cord, Remote, Cleaning Kit |
Highlight | • UST Projector Type: World's First UST Projector Designed for XBOX • Refresh Rate: HSR 240 • Latency Mode: Auto-low latency mode • Screen Size: 150" • Viewing Distance: Just inches away • Streaming Support: Google TV (Netflix, Disney+, Hulu, Amazon Prime, etc.) • Audio: Dolby Atmos & Harmon Kardon Speakers • IMAX Enhanced: Yes • Dolby Vision: Yes • Image Quality: Vivid colors, deeper contrast, ultra-realistic details |
Screen Size | 80 Inches - 150 Inches |
Throw Distance | 0.46 Meters - 0.12 Meters |
Contrast Ratio | 3000:1 |
Brightness | 3000 Lumen |
Display Type | Laser |
Picture Enhancement | Dolby Vision & IMAX Enhanced |
Viewing Experience | Overall Impression: The Hisense PX3-PRO projector delivers impressive peak brightness, making it suitable for use in moderately lit environments while providing vibrant colors. Its contrast performance excels in darker scenes, achieving deep blacks, although it experiences a slight decline in relative contrast in brighter scenes. The projector offers a wide color gamut, effectively covering the Rec. 709 color space with minimal deviations, and performs commendably in the wider Rec. 2020 space, despite minor undersaturation in certain colors. While the uniformity may not be perfect, with a brighter center compared to the edges, this projector is likely to satisfy most users seeking a quality viewing experience. |
Video Encoding | AVC |
LightSource Life | 25000 Hours |
Controller Type | Remote Control, App Control, Button Control, Voice Control |
Control Method | App |
Wattage | 250 watts |
Hardware Connectivity | Ethernet, HDMI, USB 3.0, Bluetooth 5 |
Compatible Devices | Laptop, Gaming Console, Tablet, Smartphone, Speaker |
Other Features | Advanced LPU Technology, Ultra Short Throw, 4K AI Upscaler, High Contrast Ratio, HDR and Wide Color Gamut, Dolby Vision Atmos, IMAX Enhanced, Google TV, Active 3D, Harmon Kardon Speakers |
L x W x H | 21.7"L x 11.7"W x 4.8"H |
System Experience | The Hisense PX3-PRO is a highly versatile projector that incorporates built-in Google TV, allowing seamless access to streaming content and easy integration with mobile devices through Chromecast and Airplay 2. With its powerful 50W Harman Kardon sound system, it delivers impressive audio quality, complementing the visual experience. The projector is well-equipped with multiple HDMI ports, including two HDMI 2.1 ports for enhanced connectivity and performance, alongside USB ports for added versatility. Additionally, support for Bluetooth 5.3 and Wi-Fi 6e ensures fast and reliable wireless connectivity. Overall, the Hisense PX3-PRO stands out as a feature-rich projector that caters to modern entertainment needs. |
User Feedback
Pros• Impressive image quality in dark rooms with no ambient light
• Works well with a standard white screen
• Brightness is sufficient even with some ambient light
• Compact design with a small footprint
Cons
• Poorly written documentation and setup instructions
• Complicated initial setup and calibration process
• Image sharpness and color settings are difficult to fine-tune
• Motion issues when gaming; not suitable for fast-paced games
• Remote feels cheap and lacks backlighting
• Limited sound quality compared to high-end audio systems
• Lacks certain apps like Netflix out of the box
Overall Impression
The HiSense PX1 projector offers impressive image quality for dark environments and is compact in size, making it a suitable option for media rooms. However, the setup process is cumbersome, with poorly written documentation and challenging calibration that may deter less tech-savvy users. While it performs well for film viewing, its limitations in gaming and sound quality, along with a lack of certain apps, make it less ideal for those looking for a comprehensive home entertainment solution. Overall, it's a product with potential but requires significant patience and tweaking to achieve optimal performance.
