How to beat Moltres in Pokémon Mystery Dungeon?
Pikachu
Moltres is the second legendary Pokémon you will face in the main storyline, when you escape. It is at the top of Mont Ardent. This keep is made up of 15 floors, with a rest area before the peak. So remember to prepare yourself for this moment by removing from Tatie Kangourex care items that could help you: Oran berries and resugraines, for example.
Moltres
Moltres
Moltres is a Fire and Fly type Pokémon. He therefore fears the techniques of Water, Electrik and especially Roche. On the other hand, Moltres is completely immune to Ground attacks, and resists everything that is Plant, Fire, Combat, Insect, Steel and Fairy. It makes resistance! To do more damage in one turn, do not hesitate to link two super effective abilities at Gloupti before setting off on an adventure.
What counters Moltres?
Moltres is a Fire/Flying type Pokémon, which makes it especially weak against Rock moves, and weak against Electric and Water moves.
The 5 strongest Pokémon against Moltres are:
  • Rampardos,
  • Rhyperior,
  • Terrakion,
  • Landorus (Therian),
  • Tyranitar.
PokémonQuick moveMain moveEffective damage
Rampardos Smack Down Rock Slide100%
Rhyperior Smack Down Rock Wrecker90%
Terrakion Smack Down Rock Slide88%
If you do not have enough objects or want to gain a little experience, do not hesitate to make and repeat the Passage Roc several times before exploring Mont Ardent!
