How to choose business and home projector screen?
Stefani
To have a good projection watching experience, you need a good projector and a good curtain. I know many of you know how to choose a great projector but don't know how to choose a great curtain. So I will introduce some tips on how to choose a projection curtain.
Business projector screen
Business projector screen is used in daily work office. As the projection ratio of the commercial projector is 4:3, the aspect ratio of the curtain should be basically close to 4:3. Then choose the right size for your trip. For example, if you often need to go out to work and carry the projector, it is recommended to choose an 84-inch curtain. In the meeting room, the curtain size should be determined according to the projection distance and the brightness of the projector.
Home projector screen
With the popularity of home smart projectors, more and more users are using home projectors. Home projectors typically have a projection aspect ratio of 16:9, and some widescreen projectors have a projection aspect ratio of 16:10. In order to match the room size, the home projection screen size is slightly smaller than the hanging curtain wall.
The table down below are some mainstream size of projector screens.
