Daniel
First of all, if the budget is sufficient, Sony Z9G and Z8G are worth buying if the TV demand is OLED TV; if the demand is 4K LED TV, it is recommended to start with the configuration of Sony 9500G of the flagship X1 chip, and then Sony X8500G and U8G of X1 chip (the configuration is basically the same as 8500G). Sony TV without X1 chip is not recommended.
Sony A9G
OLED TV A9G is a cutting-edge product in the television industry, which maintains the high-quality audio and painting effect that Sony always advocates, and accurately presents every detail in the picture. Even in extremely dark scenes, it can clearly show the colors and details that the picture should have. Sony A9G's performance on HD / SDR image details is amazing, with rich colors and obvious contrast. There is obvious synergy between image processor and panel. Object-based HDR remaking and dynamic contrast enhancement technologies provide a great help for image quality presentation, but they do not appear excessive. The newly upgraded flagship version of screen sound field technology makes Sony A9G more directional in sound transmission. The sound produced by people or objects in TV will move with the change of position, as if the sound is around the ear. Sony A9G is equipped with the native ad free Android 8.0 system and the intelligent AI voice function, which makes it very comfortable and smooth to run.
Sony A8G
Sony released two OLED TVs in 2019. In addition to the A9G series, it also launched a follow-up model, A8G, for the previously popular A8F. It only provides 65 inch and 55 inch models. It is equipped with 4K HDR image processing chip X1 advanced version, and Terri color display technology. Sony A8G is not equipped with Sony's latest Android 8.0 TV system. It still uses Android 7.0. Users can upgrade firmware through push update later. Compared with the flagship painting series, A8G focuses on high cost performance. Although not all of them adopt fever level standard in configuration, but the middle end hardware, together with a number of black technologies in Sony TV adjustment, A8G's audio and painting performance still has a very high level, which can be regarded as Sony TV's sub flagship model. Although it is not a cheaper OLED, A8G is still a Sony OLED that is worth buying considering brand, image quality, sound quality, quality and design.
Sony X9500G
Rtings, a well-known TV evaluation website, lists X9500G as the best 4K led Sony TV evaluated, which shows that X9500G has excellent performance. X9500G is equipped with X1 chip flagship, 1200nit screen peak brightness, support for fine control of sharp Pro enhancement, 4K sharp image processing engine pro, motionflow XR (Sony's motion compensation technology), dynamic direct down backlight, support for sharp dynamic, Android 8.0 TV system. The Sony X9500g has plateau contrast and full array local dimming support. It can display dark black in the darkroom. It has excellent motion processing ability, short response time, makes the image look clearer, and can leave fast moving objects with few fuzzy tracks. Input latency is very low, making it a great choice for gamers looking for responsive TVs. Not supporting HDMI 2.1 and broad perspective is a small weakness. Like most VA panels, the 55/65 inch X9500G has a narrow viewing angle, and people sitting on the side don't experience the same high picture quality as people sitting in front of the TV. Only the Sony 9500G, which is 75 inches and larger, uses Sony's wide-angle technology.
Sony X8500G
Sony 8500G Series LCD TVs all use 4K HDR image processing chip X1, which can fully release the display potential of LCD panel. At the same time, it can bring a wider color gamut and rich color layers, and further improve the color accuracy with the help of the Technicolor technology. In terms of sound quality, Sony 8500G Series LCD TV is equipped with a high-frequency sound field positioning speaker at both ends of the upper back of the screen, which realizes the audio-visual concept of "integration of sound and painting"; it supports Dolby panoramic sound and Dolby horizon Technology (which can be obtained through software upgrade later), which can further enhance the presence of sound and picture.
Sony U8G
Sony U8G series Sony's new products specially provided for the Chinese e-commerce market have the same configuration as 8500G, but the average unit price will be cheaper. Sony U8G content is Tencent video, and X8500G content is Huashu. U8G and X8500G are not as reliable as X9500g. X9500g adopts 4K HDR image processing chip X1 flagship processor, which has also become a direct down backlight, so it also has a sharp light control pro enhanced version. If possible, it is recommended to use X9500G.
Sony A9G
Sony A8G
Sony X9500G
Sony X8500G
Sony U8G
