Wyatt21
How to connect the amplifier to the projector? If you are trying to connect it by lines you can check the following method, which is work for common amplifiers and projectors: How to connect the projector to the amplifier However, if you are looking for a method for bluetooth amplifier, you are recommended read the following article:
How to connect a bluetooth amplifier to projector?
Wireless connection is the way to connect a bluetooth amplifier to projector via Bluetooth technology. The old power amplifier may not have Bluetooth function, you can buy a Bluetooth transceiver. First, move the bluetooth amplifier in operating state close to the projector.
Bluetooth connection method:
When performing Bluetooth pairing, you can first turn off the Bluetooth function of the bluetooth amplifier, which can help the projector to pair with the Bluetooth connection of the amplifier.
Advantages of wireless connection: No need to use audio cable, no need for for home wiring :
Disadvantages: the bluetooth amplifier sound quality will be poor due to connection method
In general, the two methods of projector connection are good and bad. There are pros and cons, the specific choice depends on the users themselves. It is also worth mentioning that the built-in sound of the current smart projection is also quite good.
1. Turn on the Bluetooth amplifier and enter the Bluetooth pairing mode;
2. Turn on the projector's Bluetooth function and select "Search devices", and the corresponding device is successfully paired to complete the connection.
