Robert
How to connect the TV box to your TV?
1. First find the HDMI port on the back of the TV, and use the HDMI cable to connect both ends of the box and the TV port (if you have an old TV at home that doesn't have an HDMI port, please use an AV cable to connect.
2. Select HDMI as the signal source on the TV (select according to the actual signal source).
3. Connect the other end of the HDMI cable to the TV box.
4. Power on, then you can use your TV box. (If the picture cannot be displayed, please check whether the HDMI interface is broken or the TV resolution is too low. At this time, you can change the AV interface to check the cause. )
