How to Download Hulu on Samsung Smart TV? Setup Guide
Looking to stream your favorite Hulu shows on your Samsung Smart TV but not sure how to install the app? You’re not alone! Whether you're using a newer Tizen-based model or an older version of Samsung Smart TV, this guide will show you exactly how to download and set up Hulu.
Here’s a step-by-step breakdown that works in 2024 and beyond.
Can You Get Hulu on Samsung Smart TV?​
Yes—Hulu is officially supported on Samsung Smart TVs from 2016 and newer that run Tizen OS. For older models, there are still ways to watch Hulu using a workaround (covered below).
How to Download Hulu on a Samsung Smart TV (Tizen OS Models)​
If your Samsung TV was made in 2016 or later, follow these steps:
Step-by-Step Instructions:​
  1. Turn on your Samsung Smart TV and connect it to Wi-Fi.
  2. Press the Home button on your remote to open the Smart Hub.
  3. Navigate to the Apps icon and press Enter.
  4. Select the Search (magnifying glass) in the top right.
  5. Type “Hulu” using the on-screen keyboard.
  6. Click on the Hulu app from the search results.
  7. Select Install.
  8. Once installed, go back to Home > Apps and open Hulu.
  9. Log in with your Hulu account or activate via the code on hulu.com/activate.
💡 Pro Tip: Make sure your TV’s software is updated before downloading apps to avoid compatibility issues.
Requirements to Download Hulu on Samsung Smart TV​
RequirementDetails
TV ModelSamsung Smart TV (2016 or newer)
OSTizen OS (no support for Orsay models)
Hulu SubscriptionBasic, No Ads, or Hulu + Live TV
Internet ConnectionMinimum 3 Mbps (SD), 6 Mbps (HD)
Can’t Find the Hulu App? Try This:​
If Hulu doesn’t appear in your Samsung App Store:
1. Check Your Region Settings​
  • Hulu is only available in the U.S. and certain U.S. territories.
  • Go to Settings > General > System Manager > Language & Location.
  • Make sure the TV region is set to the U.S.
2. Update TV Software​
  • Go to Settings > Support > Software Update > Update Now.
3. Reset Smart Hub​
  • Settings > Support > Device Care > Self Diagnosis > Reset Smart Hub.
  • You may need to re-login to your Samsung account afterward.
How to Watch Hulu on Older Samsung TVs (Orsay OS or pre-2016)​
Samsung TVs made before 2016 do not support the Hulu app natively. But you still have options:
Option 1: Use a Streaming Device​
DeviceWorks With Hulu?Notes
Roku✅ YesEasy to install, affordable
Amazon Fire Stick✅ YesPlug-and-play setup
Apple TV✅ YesBest for Apple ecosystem users
Chromecast✅ YesCast from your phone or tablet
Game Consoles✅ YesPS4, PS5, Xbox One, Series X/S
Option 2: Screen Mirroring from Phone​
  • Use Smart View (Samsung phone) or AirPlay (iPhone) to mirror Hulu to your TV.
  • Both devices must be on the same Wi-Fi network.
  • Performance may vary, especially for live content.
How to Activate Hulu on Samsung Smart TV​
After installing, you’ll be prompted to log in. You can do this in two ways:
Option 1: Enter Email & Password​
  • Just input your Hulu account credentials directly using your remote.
Option 2: Use Activation Code​
  1. A code appears on your TV screen.
  2. Go to hulu.com/activate on your phone or computer.
  3. Log in and enter the code.
  4. Your TV will automatically log in.
Frequently Asked Questions​
Q: Why isn’t Hulu showing up in my Samsung TV App Store?​
A: Your TV model may not be compatible or your region settings are incorrect. Make sure your Samsung account and region are set to the U.S.
Q: Is Hulu free on Samsung Smart TVs?​
A: No, you’ll need a paid Hulu subscription, though free trials are available for new users.
Q: Can I download Hulu Live TV on my Samsung Smart TV?​
A: Yes. Just log in with a Hulu + Live TV subscription after downloading the app.
Final Thoughts​
Downloading Hulu on a Samsung Smart TV is quick and easy—if you have a 2016+ model with Tizen OS. If not, you can still watch Hulu using external streaming devices or screen mirroring.
Here’s a quick recap:
ScenarioWhat to Do
Samsung TV (2016+)Use Smart Hub > Apps > Install Hulu
Samsung TV (Older)Use Roku, Fire Stick, or mirroring
Hulu not showing upCheck region, update firmware
Related Reading:
Hulu not working on Vizio smart TV, how to fix?
Same issue here on a 2019 set: the Apps store shows Hulu but the install just hangs. Firmware's moved on a couple versions since, so I'm curious what actually worked for you—did a reinstall or a factory reset do it?
