If you're wondering how to install application in LG Smart TV, you're in the right place. Whether you want to download Netflix, YouTube, Disney+, or a fitness app, LG's smart platform (webOS) makes it easy to find and install the apps you need.
This guide covers everything: step-by-step instructions, troubleshooting, and tips to optimize your LG TV app experience.
Before we dive in, make sure your LG TV runs webOS 3.5 or higher, which supports most apps and services available in the LG Content Store. To check your TV's software version:
Follow these steps to install applications easily:
This is LG’s official app store where you can find, browse, and download new applications.
Once installed, the app will appear in your Home Dashboard or Launcher Bar.
Keeping apps updated ensures better performance and access to new features.
You can install:
Note: LG Smart TVs do not support APK files or third-party apps from external sources unless you use external devices like Fire Stick or Chromecast.
Related Reading:
How to Get Netflix on Smart TV? Step-by-Step Guide
How to Watch Amazon Prime on Smart TV?
Compatible LG Smart TVs
- Press the Settings button on your remote.
- Go to All Settings > General > About This TV.
- Look for the webOS version.
How to Install Application in LG Smart TV
Step 1: Connect to the Internet
- Navigate to Network > Wi-Fi Connection.
- Select your home network and enter your password.
A stable internet connection is required to access the LG Content Store and download apps. Check LG Smart TV Not Connecting to Wi-Fi Troubleshooting Guide
Step 2: Open the LG Content Store
- Press the Home button on your LG remote.
- Navigate to the LG Content Store icon and select it.
Step 3: Search for the Application
- In the LG Content Store, go to the Search (
) icon in the top-right corner.
- Type the name of the app you want (e.g., “YouTube” or “HBO Max”).
Step 4: Download and Install
- Select the application from the search results.
- Click the Install button.
- Wait for the installation to complete.
Bonus: How to Move or Delete Apps
- Press Home > highlight the app > press and hold the OK button.
- You can now rearrange, delete, or move apps as needed.
Common Issues & Solutions
Can’t Find the App?
- Region restrictions may apply. Try switching the TV’s region (Settings > General > Location).
- The app may not be available on older models.
Installation Fails or App Crashes?
- Check your internet connection.
- Update your TV software (Settings > All Settings > General > About This TV > Check for Updates).
How to Update Installed Apps
- Go to the LG Content Store.
- Navigate to My Apps.
- If updates are available, you’ll see an Update All button or specific update options.
Supported App Types
You can install:
- Streaming apps: Netflix, Prime Video, Disney+, Pluto TV
- Music apps: Spotify, Tidal
- Lifestyle apps: YouTube, Peloton
- Utility apps: Weather, Web browser
Summary: How to Install Application in LG Smart TV
Step | Action |
1 | Connect to Wi-Fi |
2 | Open LG Content Store |
3 | Search for the app |
4 | Install and launch |
5 | (Optional) Rearrange or delet |
Related Reading:
