How to open Fire TV remote?
LopS
Do you have some problems with the Fire TV remote when you first get it? Many beginners of Fire TV are looking for the creative ideas for how to open the fireTV sticek ore fire TV cube remote. Actually it's very easy if you master these tips.
Actually we need to open the remote to set the batteries and the control the Fire TV. First, just hold both ends of the remote, squeeze both ends gently and slide forwards. Then you can put the baterries into the slot and cover it. Simple and clear, just do it.
However, sometimes you may find it hard to open it gentally. In this case, you can try to pull it hard. If it still doesn't work, pry to open it with a screwdriver.
