How to set up your Sony Android TV?
Felia
If you bought a Sony Android TV, you don't just unplug the power cord from the box and plug it in, you need more time to set up your Sony TV for the first time. This guide will walk you through the first-time setup process.
How to set up Sony Bravia Android TV?​
You can use your TV directly and power it on, now it's time to set up your Sony Android TV.
1. Choose your language preference on the Welcome page.
2. Decide if you want to use your Android phone to set up the TV. The great thing about an Android phone for Android smartphone users is that your phone can use Quick Setup to quickly transfer your network settings and Google account to your TV. If you don't have an Android phone, or want to continue with the manual setup instructions, select Skip.
3. Select your W-Fi network name and enter a password or select Skip. You can connect your Sony smart TV to Wi-Fi anytime. For steps on how to run the Sony Smart TV Wi-Fi setup process, see How to set up Sony TV to Wifi.
4. Select Accept on the Terms of Service page.
5. Select Yes or No to decide if you want Google to use your TV location to personalize your experience with local programming. this is your choice.
Select Yes or No
Felia
6. Choose Yes or No to decide if you want to send feedback to improve Android TV. Again, the choice is yours.
7. Follow Sony's steps to guide you through your new TV. After you click on the introduction, a short clip will take you to the secondary settings menu.
8. Choose your region.
Choose your region on sony tv
9. Scroll down to view the Sony Bravia Privacy Policy. When you scroll to the end, you will be able to use your TV data to agree to Sony. Choose which items you agree with, agree with everyone, or proceed without consent.
10. Approve or reject voice recognition if you have previously connected the TV to WLAN. If you haven't already connected the TV to Wi-Fi, select Next.
Felia
11. Choose how you receive channels, whether it's a satellite box via HDMI or an antenna via the built-in tuner. If you don't have a cable, you can also skip to step 13.
Choose how you receive channels on sony tv
12. Set up the cable: If not already connected to your device. You can optionally set up your Sony TV remote so that it can now control your cable channels. Power on the cable box and select the input you want to assign to the cable. Enter your zip code and select your service provider. Point the remote at the cable box, select Prog Up, and confirm that you see the channel change. Do the same for menus and changing channels.
Set up the cable on sony tv
13. Select the peripherals you want to set up on the TV. This might include your cable box, soundbar, Blu-ray player, etc.
14. Choose whether your TV is standing or standing on the wall for audio tuning.
15. Run or skip the acoustic autocalibration. This will optimize the TV's sound within its space, so we recommend running a calibration and selecting "Allow". Note, however, that a series of sounds will play and surprise you. If you do not want to set up acoustic auto-calibration, skip to step 17.
16. Sit where you normally watch TV and select Start to start the calibration. After the calibration is complete, select Next.
17. Select Done to finish.
You have successfully set up your Sony Android TV. You can see the guide on How to Download Apps on Sony Smart TV to know more about how to use your Sony TV.
