If you don't have a remote control, then you might be in trouble. Do you have to buy a new universal remote to set up your Inignia TV? Do not. This article will provide two useful methods to help you successfully set up your Insignia TV without a remote.
First, you need to download Remote for Inignia TV on your phone. It can be easily downloaded in just a few simple steps.
1. Search and download Remote for Inignia TV from the Google Play Store.
2. Open the app and select your Insignia Fire TV.
3. You will see the remote button on your phone's smart screen.
4. Now you can use this app like a remote control and it will help you to set up your Insignia Fire TV.
Then, set up your Insignia Fire TV with Remote for Inignia TV.
1. Click the Home Button , then click the right navigation key.
2. Go to "Settings".
3. First, connect your internet connection via network settings.
4. Now you can also make other settings with the help of the Internet.
5. You can make changes as you wish.
In addition to using Remote for Inignia TV, you can also set up your Insignia Fire TV via the power button.
1. First, unplug the TV and hold down the power button.
2. Plug the Insignia TV power cable again.
3. Press and hold the power button until the menu opens on the screen.
4. There you can see many options and you can set up Insignia Fire Tv.
5. Select the option you want by pressing the power button again and again.
6. You can make all the required settings according to your needs.
That's all for how to set up Insignia TV without remote. Hope they will help you.
How to set up your Insignia TV with Remote for Inignia TV?
How to set up your Insignia Fire TV from the power button?
